Question about Nvidia GeForce2 GTS Graphic Card
Upgrading with zip
Maybe its just me but how do I install an upgrade to my graphics and drivers from a zip file I downloaded
    Scholar:
  • 47 Answers
  1. Unzip the file to folder in a location you know
  2. Check the files if they have a set up application file then run it
  3. If they dont have an application file then goto my computer icon right click and selct properties and then select the hardware tag followed by device manager then goto your hardware profile right click your hardware icon and select update then choose option to udate manually and click next and show it under browse icon where the file is located then click next, if your driver is not signed by windows but is from a trusted source click next if the query comes on otherwise wait for clicking finish
  4. Guess what you just did it
Posted on Mar 24, 2008
Unable to install Radeon HD6450 2gb Graphic card on ASUS P5RD2-VM Motherboard. I am using 32 bit Window xp
Hi, you can download a manual here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5RD2-VM&p=1&s=22
Please select your operating system.
Select manual and click on global.
Unzip the file before you can read it.
Upgrade the other drivers if some missing.
Run also windows update.
You may have to disable the onboard graphic in the bios.
You can also try to upgrade the bios by using the
asus upgrade utility.
The graphic card must be a PCI-E socket.
I guess the old driver is making a conflict as it is the same brand.
And download the latest driver for your graphic card here:
http://support.amd.com/us/gpudownload/windows/Pages/radeonaiw_xp.aspx?type=2.4.1&product=2.4.1.3.48&lang=us&rev=&ostype=Windows XP - Professional/Home
Sep 09, 2011 | ASUS P5RD2-VM Motherboard
How to install upgrade in transcend mp850
Here is a link for firmware upgrade od your mp850:
http://www.transcendusa.com/Support/DLCenter/dllogin.asp?Link=dlcenter'Driver'MP850FWV2.05.zip
After decompressing the .zip file please read the Firmware Update Procedure pdf document. It is described how to do this.
The .zip file contains the .pdf and .exe files too.
Thanks.
gylacz
Jul 11, 2011 | Transcend T-Sonic 850 Digital Media...
Internal Error : 0x2025 - 0x08X - 0
Uninstall any current version of vSpace. Reboot. Make sure you have no missing or conflicting device drivers inside of device manager. Also, while in Device Manager, navigate to the Ports Section and see if there is anything listed for Intel Active Management Technology. It will be listed as IAMT or SOL/COM3. If so, right click it and disable it. Then run the NComputing cleanup utility located here: www.nc-eng.com/tools/ncuninstall.exe. Download current version for XP from here: www.ncomputing.com/download/x300. Unpack the .ZIP file and install. Reboot and register.Do NOT, I repeat, do NOT install from the provided CD and upgrade. Simply install straight from the download file I provided in the link.
Feb 23, 2011 | NComputing X300 3 User Expansion Kit...
Drivers not aviable with me
Uninstall any current version of vSpace. Reboot. Run the NComputing cleanup utility located here: www.nc-eng.com/tools/ncuninstall.exe. Download current version for XP from here: www.ncomputing.com/download/x300. Unpack the .ZIP file and install. Reboot and register.Do NOT, I repeat, do NOT install from the provided CD and upgrade. Simply install straight from the download file I provided in the link.
Jan 11, 2011 | NComputing X300 3 User Expansion Kit...
Bad audio
Not sure what you mean by bad audio. Does it work at first and then the sound deteriorates? Does it not work on any of the stations at all? If you have a dual card setup, does it work on one card and not the other? You might try to upgrade to the latest software, v4.03.104.1. To do so, uninstall any current version of vSpace. Reboot. Make sure you have no missing or conflicting device drivers inside of device manager. Also, while in Device Manager, navigate to the Ports Section and see if there is anything listed for Intel Active Management Technology. It will be listed as IAMT or SOL/COM3. If so, right click it and disable it. Then run the NComputing cleanup utility located here: www.nc-eng.com/tools/ncuninstall.exe. Download current version for XP from here: www.ncomputing.com/download/x300. Unpack the .ZIP file and install. Reboot and register.Do NOT, I repeat, do NOT install from the provided CD and upgrade. Simply install straight from the download file I provided in the link.
Dec 31, 2010 | NComputing X300 3 User Expansion Kit...
I dont know how to install the firmware for my mp4 i really need help
Do you have the CD for the SMPK8858 ?
Then put the CD into the CD drive or DVD drive of your computer and explore the CD, for the firmware update look under:
\Firmware Upgrade tool\ConsumerUpdate 3.1.2.0\setup.exe
1. explore or double click folder Firmware Upgrade tool
2. explore or double click folder ConsumerUpdate 3.1.2.0
3. run or double click file setup.exe: this will start the installation of the update software on your computer.
After the installation of the setup.exe file, run the firmware update program to start the update for your player.
Most Sylvania players will have a CD provided. When you don't have it, download the driver (a zip file) from Curtis:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK8858_DRIVER.ZIP
After the download unzip the file with WinZip or WinRar:
now look for the firmware installation program under
SYL_SMPK8858_DRIVER \ SMPK8858 \ Firmware Upgrade tool\ConsumerUpdate 3.1.2.0 \ setup.exe
Double click the setup.exe, the same procedure as when using the CD.
There is also a manual for SPMK8858 (a pdf file) online:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK8858_EN.PDF
Jul 17, 2010 | Sylvania SMPK8858 MP3 Player
I bought a brand new Asus CG5205-AR003 W/Intel core i5 650gig/8gram. Installed PNY GeForce9800GT and running Windows 7 Home premium. Installed my old version of Pinnacle Studio 11 then upgraded to Studio...
Ok you need to UNZIP this file BEFORE you use it. Then go to the Unzipped file location, and then run the install/setup .exe. get Download, WinRAR this will uncompress/Unzip many formats.
http://download.cnet.com/WinRAR-32-bit/3000-2250_4-10007677.html
Feb 22, 2010 | Pinnacle Studio Plus Version 11
Display adapter
You will have to get a "Driver" for your Video Adapter. This WILL be a problem as there probably isn't one. There may be one shot, try this. Download your Video Adapter's XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all
The drivers are here INTEL, right at the bottom.http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_P4_1150&hidos=WLH&hidlang=en&TabIndex=
Feb 03, 2010 | Dell Inspiron 1150 Notebook
Zip download
What are these upadte for this solution is assuming they are hardware drivers updates
  1. Unzip your file into a file in any location even my documents
  2. Open the files and check if they contain any set up application file if yeah then run it
  3. Otherwise goto my computer icon right click and select properties and then goto to the hardware tag and select device manager
  4. under device manager select the hardware you want to update and right click and select update
  5. Select manual opttion and click nect and then under the browse tag select the folder where you unzipped the files and click next
  6. If a windows signing window pops up click next if these drivers are from atrusted source which is not yet approved by windows
  7. Click finish
  8. guess what? What? you are done Brilliantly
Mar 24, 2008 | Nvidia GeForce2 GTS Graphic Card
About installed software..
I think that “Microsoft pocket pc 1996 - 2003 os” called now “Windows Mobile 2003”. To upgrade your PDA to 2003SE please go to TOSHIBA Site http://www.toshiba-europe.com/. Than go to Computer systems. Under “Support &Downloads” there is option Download Drivers. Please chose your PDA and there are all useful Drivers for “Windows Mobile 2003 SE”. In every zip File there is “Upgrade Guide”. Read it. It can help you to make update without problems.
Sep 08, 2005 | Toshiba e805
Nvidia GeForce2 GTS Graphic Card Logo
Top Nvidia Computers & Internet Experts
David
David
Alun Cox
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
