Question about Brother LS-1520 Mechanical Sewing Machine
Sewing on reverse of fabric
I have been using the sewing machine and all of a sudden the stich I was sewing started to be sewn on the reverse (underneath) of the fabric when I require it to be on the fabric front. Can you help?
    Genius:
  • 1,116 Answers
There has to be thread on both sides of the cloth in order to form a stitch.
Refer to the maintenance section of your machine and clean the machine as recommended.
Did you change the thread or needle?
Check the manual to be sure the threading is correct and was done with the presser foot up.
Is the needle is correctly installed?
Check the bobbin to be sure the thread is feeding in the correct direction and through the guides on the side of the bobbin case.
Posted on Apr 29, 2010
How to adjust tension janome 4400
Before you go changing settings... make sure you are stabilizing the fabric correctly. Towels especially requires a stabilizer on top AND on bottom.
Dec 06, 2012 | Janome MC 4400 Computerized Sewing Machine
Sewing in reverse cuts top thread, help? Please!
the fabric & thread & needle may not be compatable
try changing the needle- it may be damaged
the horrible grinding noise needs to be check --the machine needs to be serviced
check for burrs on the needle plate & on the bobbin
some sewing machines don't do with strong material
Mar 18, 2012 | Sewing Machines
Can this machine sew over pins?
You must remove the pins as you sew otherwise you will either break the needle or do worse damage to the machine. Home sewing machines were never meant to sew through metal.
Feb 04, 2011 | Brother LS-2220 Mechanical Sewing Machine
Skips stiches
This is normally a needle related problem, change the needle for the type of fabric to be sewn. If it is a stretchy fabric, get a "stretch" needle.
Good Luck
Oct 18, 2010 | Kenmore 744-08BH Mechanical Sewing Machine
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Stitching is too loose
hi! this particular problem is common when tension and stiches adjustment does not match and complied to fabrics your trying to sew,there a is hard way to find manual specialy to old ones. but if you want it may help you some i got here on manual sears 1803.if your control look similar to this in figure5180e2c.jpg there are stitch control one for straight stitching and one
on special stitching.the small dial near needle is tension dial.You can set tension on # 3 to 5
stitch dial as in figure7a4913a.jpgif you are
sewing a straight stiches set to # 8 to 12 trial are needed somtimes to acquired smooth sewing,Be sure no mechanical problem regarding in machine operation.try to sew a cotton fabric for trial then if sewing another fabrics sudden adjustment should be done.If your machine is equipted by auto tension just select on the fabrics.well small information can sometime helpfull ...nice sewing
Mar 18, 2009 | Kenmore Sewing Machines
Stitch problems
You can adjust the pressure foot(not footpedal)which puts the prsure on the foot by the needle. Also try altering the stitch length. If the stitches are skipping on silky fabric or knitted fabrics try using tissue and sewing onto that directly then tearing it off afterwards.
Nov 12, 2008 | Janome Sew Precise Mechanical Sewing...
Brother LS-2125 presser foot stuck
i bought a new brother stiching machine ls2125. when i started to stich the same no stiching is coming only the mark is coming. why?
Sep 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-1520 Mechanical Sewing Machine Logo
69 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
