Question about Cobra Mr Hh325 Vp Handheld Vhf Radio
I have a Cobra HH325 with asheared antenna mount
I have a Cobra HH325 on which we have managed to snap off the antenna. The antenna is fine but half the threads of the mount are sheared off. Has anyone obtained and/or fitted a new mount?
  • 3 Answers
SOURCE: Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Posted on Dec 24, 2008
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Posted on Jan 07, 2009
  • 7 Answers
SOURCE: high SWR
the problem is in the antenna cable. the lenth of a antenna cable must be divisable by 3. try replaceing cable with a 18 foot cable that should fix the problem.
Posted on Apr 22, 2009
  • 773 Answers
SOURCE: i set the swr on my antenna and it keeps moving i
1) if you are talking, your SWR will most likely move. You must take the reading while not modulating, (talking into the mic)
2) Window mount antenna's are GARBAGE. they are worthless. BAD BAD BAD. You wasted your money. Get a mag mount.
3) if you are not in an open lot, your SWR's will be different due to structures reflecting signal back. Always take your SWR reading in an open lot.
4) You could be experiencing Common mode currents. Normally the signal travels on the inside of the coax ground. Common mode current is when the signal is traveling back down the coax on the outside of the ground in the coax. (The biggest cause of this would be the window mount antenna). If you want to keep that garbage antenna, then you can make an RF choke in the coax. The best solution is get a better antenna. Here is how to make the choke. As close to the antenna as you can, take 6 ft of coax and loop it uniformly laying each coil next to the other. use electrical tape to hold it in place. You want 6-8 wraps. You want a nice uniform coil.
Just get a better antenna. Window mounts are the worst. You get horrible receive and horrible transmit. Get a wilson 500 mag mount. It will work so much better for you.
Posted on Apr 24, 2009
Benimur
  • 6966 Answers
SOURCE: cb problem have a cobra 19dx iv with a 2ft magnet
Hi and welcome to FixYa,
Which output is muffled, transmit (modulation audio) or receive audio?
If you are referring to the receive audio, initially, have you tried an external speaker? If it works good, then it would be an internal speaker problem; if not then others to check would be:
  • IC1 - KIA7217AP audio IC;
  • CM 10 & 15 - audio output capacitors 470uF / 16V.
if it were transmit / modulation audio, try replacing the mic.
Please postback updates.
Good luck and thank you for asking FixYa.
Posted on Aug 01, 2009
I have a Cobra Mr HH325 hand held Marine radio. Everything works fine except recently I can't transmit more than a hundred yards. What can I look for to check what is wrong?
the way the airwaves have been lately , although it shouldn't have any effect on marine radios ,you should be glad to get out even a mile or two. Either the air waves are dead of there is so much skip.
Jul 20, 2014 | Cobra Radio Communications
Cobra XL 29 Anntena Warning Light
If you have a SWR meter.put meter in line with coax. Dubble check coax and make sure its not pinched,cut. Antenna mount is tight and clean. No electrolysis build up At connection. Warning light is coming on for a reason. something is wrong in between radio and connection at the antenna.
Nov 23, 2012 | Cobra Radio Communications
Cb antenna warning
If your readings are below 0.5 with a dipole that is a excellent swr reading, most fall in the area of 2.0 or higher, you will not harm your RF output transistor, if you are getting antenna warnings see if you can recalibrate it.
May 04, 2012 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Bought a new cobra 29, need antenna advice
Firestik Dual CB Antenna Kit This is a most popular dual antenna kit and one we HIGHLY recommend! It contains everything you need and features premium USA-made components from Firestik. The included FS CB antennas are our best-selling antennas and ensure you'll receive maximum transmit and receive performance. Designed for the elements, the stainless steel springs and mounts are rust- and weather-resistant. The included three-way mounts -- the most popular style we carry-- offer numerous mounting possibilities.
Dec 22, 2009 | Cobra 29 LTD CB Radio
I have a Cobra 29 LTD with Bluetooth. I have no static no matter where I set my squelch and RF gain unless my noise blocker is off. Both my rx/tx and antenna lights turn red when mic is keyed. I have try...
if the antenna warning indicator is lighting during transmission then the antenna is either located and.or installed improperly or a defect exists in the antenna mount or the feedline itself, including connectors.
Jun 08, 2009 | Cobra 29 LTD CB Radio
Transmitting fine, not receiving an single thing..
the problem could still be with your swr . If your jeep is fiberglass at the point where your antenna connects that could be the problem. move it to a point where there is metal to get a good ground plane and you should hear people talking.
Apr 25, 2009 | Cobra 150 GTL DX Base CB Radio
Dec 20, 2008 | Cobra 29 LTD CB Radio
Dec 05, 2008 | Cobra 29 LTD CB Radio
Cobra 19 DX IV
No, those radios are good radios. I have one just for setting swrs on antennas.
First, I went back and read your last question. You said you have a nylon washer on top AND bottom? Did you mean one under on the top and bottom side of the antenna mount? You only need theone on the top of the antenna mount, which stops the antenna itself from being grounded out. Having one on the underside stops the outter part of the stud, the one that touches the outer screw on part of the coax from being grounded. Without that getting a good ground, you have no groundplane, which will cut your tx/rx to a max of 2 miles. Also, how close is the two setups. Many times, if two vehicles are setting next to each other, you will not receive or transmit properly, just get a nasty garbled with a hint of a squeal.
If this doesn't help, please reply here or shoot me an email at:
rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Mt. Vernon, TX
May 15, 2008 | Cobra 19 DX IV CB Radio
Cobra Mr Hh325 Vp Handheld Vhf Radio Logo
89 people viewed this question
Top Cobra Boating Experts
RFburns
Level 1 Expert
Electro Med Services...
Are you a Cobra Boating Expert? Answer questions, earn points and help others
