Question about Dell Computers & Internet
The screen of my laptop turn to small - Dell Computers & Internet
    Sergeant:
    Champion:
  • 305 Answers
GO TO start then control panel then double click display go to the settings tab then you can move the slide up or down to change the size on screen.
hope this helps.
Posted on Apr 29, 2010
What's your problem? Computer is on but screen appears blank.
this is most likely caused by the 'screen on' switch - on some pc laptops its an actual switch and you can identify it because its a plastic pin protruding near the hinge and when you close the lid the pin is depressed turning off the screen it may have become stuck in the don position turning off the screen on some PC laptops its a magnetic switch and can be re-activated by running a small magnet along the hinge or along the outer lower edge of the laptop near the touch-pad - If neither of these work try restarting in 'Safe Mode' by pressing 'F8' repeatedly on start-up and selecting safe mode, then changing what ' closing the lid does ' by clicking on 'Start - Control Panel- Power Options'..No screen still after trying to get to 'Safe Mode' means you may need a new screen replacement...
If the magnet works then keep all little magnets away from your laptop in future - this includes those little annoying ones at the tip of some devices like mechanical clutch pencils, cellphone cases, and other small cases that do not have a visible latch to close them.....
Sep 25, 2011 | Computers & Internet
How to turn on wireless
Hi Bickett,
to turn on your Wifi on your laptop, search for a button which looks like a satellite and press it with your fingers to turn it on.
Hope this helps, good luck!
Mar 15, 2011 | Dell Studio 17 Laptop
I put my chip in the laptop , edited colors and turned it around, my laptop Is vista. And when I put it back in the camera it was small?
Do you means you edited the picture's color and turn the picture around?When you do a turn of the picture, it will be seems small. as the length and width has a turn the camera's screen are not at that proportion
Jan 14, 2011 | Sony Cyber-shot DSC-T20 Digital Camera
Laptop turns on and the monitor only turns on for a second.
you need to open the laptop and check the screen, it is possible that the flex or screen inverter that connects the screen to the laptop motherboard has shifted or has loosed contact or is not firm to its right position.
All you need to do is to open the laptop, if the flex is removed, fix it back to its right position and that's all.
Also, do a general troubleshooting on the screen and the problem should be solved.
Good luck.
May 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
1) I have a Toshiba Pro 600 model ps600c-01qw4. The problem of this laptop is that when i turn the computer on the screen is very small. So I went into the display setting and fix the problem. But when i...
Check the monitor in the device manager. NOT regular display properties. Make sure the monitor is the correct type. Try different settings in device manager for the monitor. Maybe try uninstalling the video card drivers, reboot and reinstall the drivers. Let me know if this does not work.
Joe
May 17, 2010 | Computers & Internet
The screen quit and I need to turn on the external monitor port
Look on your keyboard, along one of the top 2 rows you'll see some symbols as alternatives to the main key function. One will be a small picture of a TV screen.
Press the key Fn and the small screen key together.
May 12, 2010 | Acer Aspire 3610 Notebook
I have a acer aspire 4715z..but i got a problem..when im turn on my laptop,a black screen appear. .whats the problem??
look on your laptop for a small tab it should be some place neer the top of the keyboard its made so when you shut the top of the laptop it turns of the screen some times the button gets stuck it should be a small black button...
Jan 22, 2010 | Acer Computers & Internet
While on laptop screen goes black except for a small 1" white box
hi
its ur video card problem so u need to get it upgraded
and for our tchnician help call at toll free no 18884276640
Jun 23, 2009 | Dell Inspiron 1501 PC Notebook
Replace Memory
Link
click on the links on the page for removing dimm A
1. Preparing to work inside
2. Removing hinge cover
3. remove keyboard etc.
Aug 21, 2008 | Dell Inspiron XPS M140 Notebook
Problems with My Monitor Screen.
Sony vaios are very tempramental.
Did you drop or bang the machine, before this happened ?
There are a few suggestions.
1:) the screen catch mechanism is jammed.
Solution:- turn on laptop, using a small blunt screwdriver. where the laptop latch, goes into the laptop base. gently push the latch mechanism a few times, to see if it,s jamming.
2:) if the screen display shut off mechanism is under the actual laptop screen lid, push the small plunger, up down several times.
These are common likely causes.
3:) press and hold the power on button for 15-30 seconds, this is in case the system has gone into hibernate/sleep mode.
4:) ensure The battery is fully charged. And the laptop power supply is plugged in.
If none of the above work for you, you may need to take into a repair specialist.
Mike @ compurepair.
Mar 29, 2008 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Computers & Internet Logo
Alun Cox
