My printer will not print documents. Sometime ago I booknmarked cupon.com and that required a different installation printer to be added. Please help i do have a usb cord also
  • newbeginn544 Apr 30, 2010
    how do i download the app? this is very frusterating, pls help me again. Thanks
    Scholar:
  • 118 Answers
I once experienced this. it's not the printer, sounds like you need to download the printer format from the web site in order to print the coupons.
check the site to download the additional program layout format.
let me know how it turns out.
hope this helps and good luck
Posted on Apr 29, 2010
How do you print to a specific tray on bishub c654 in mac 10.7
you are using different printer driver. install a exact driver for the machine
Feb 27, 2013 | Genuine Konica Minolta Konica Minolta...
Error message from printer properties : Can not print test page. This operation can not be completed. Take note that printer self-test is working and from printing option cleaning cartrige work perfectly....
You need first to do the following:
Check first a different usb cable ( be the case).
Check that the printer is the default printer or you are not printing to a different printer installed in windows
Do driver setup procedure.
Disconnect printer from usb.
Go to 'installed printers' and remove the printer from windows (right click and delete). If you have documents in printer cue you may need to purge documents in cue.
Restart computer (printer disconnected).
Re-install drivers from disk (printer disconnected).
Only connect printer to usb when required by printer install software or after installing software.
If the above did not work the printer can be faulty, in this case usually it shows some dignostic message, like flashing red light etc.
Check also that is not a windows problem, by installing in on a different computer (get a laptop) and printing a test page.
Regards
Apr 15, 2008 | Office Equipment & Supplies
I dont get any error, nor do I get any documents added to the printer spool. Tried on win7x64 and Vistax32; no error, no documents. Printer is currently attached USB to Vista Home Basic x32. When...
go to printer & fax right click on the printer c5580, then click on set as default printer be sure to check this setup when you try to use it on another computer thanks
Aug 03, 2011 | HP Photosmart C5580 All-In-One InkJet...
On HP 5MP laserjet Printer, on printing a document, the message says: the printer requires more memory than is avaailable in this printer.what to do then?
You don't say what kind of a document you are trying to print. Did you try to print something else. Did it print?
Normally if you try and print a complex spread sheet you may get that warning. You have the option of adding more memory or making your print job less complex. Or printing to another printer.
Oct 03, 2010 | HP LaserJet 5mp Printer
My software is windows xp 2003, and my printer model is HP Deskjet 3745.my question is? Is this compatible to access my printing works?
Sometime operating system doesn't determine compatibility, but most of the times it does. it will be better for you to check the instruction manual that came with the printer to see the system requirement. if your system met the system requirement of your printer, it will sure print. what determine the compatibility is if your system is able to interact with your printer after the installation of the drivers that either came with your printer.
Therefore, your window xp will be able to work with your printer if you install the driver that will enable it to interact with your PC, a CD-ROM or software always come with the printer, install the software and follow the necessary steps. after the installation your PC should be able to connect to your printer, and you can then print any document.
Regards
Jul 05, 2010 | HP DeskJet 3745 Printer
Double images, error 5100 when printing, copying
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Jan 02, 2010 | Canon PIXMA MX700 All-In-One InkJet...
When printing PDF colour documents data is missing I understand that adding memory may solve this - is this an easy thing to do , and is there a maximum memory I can add
Adding memory won;t help you. You have to set the print preferences to include everything in the document. If you are getting blue blocks with no data in them, uncheck the "Print Highlighted areas".
As for memory, each computer is a little different. Tiger Direct dot com has a memory checker. It will tell you how much and what type memory your system uses.
Oct 02, 2009 | HP DesignJet 500ps InkJet Printer
Printer won't print word perfect doucments
try a different pint driver such as a pcl4or5e.
Apr 15, 2017 | Office Equipment & Supplies
HI I HAVE JUST REPLACED THE INK IN MY CANON MP 760 PRINTER. ON THE PRINTER ITSELF HOWEVER, AFTER OPENING A DOCUMENT (WORD) TO PRINT, IT FAILS TO PRINT. THE PAPER IS STILL FED TROUGH AS THOUGH IT IS...
Check that is defined as default printer in 'installed printer' in Windows, and that you are not sending documents in printout to another non connected printer present in Windows under 'installed printers'.
Unplug completely computer from power socket and from USB for 10 minutes, to get rid of electrostatic problems on USB. Plug everything back and restart.
Check the USB cable, replace USB cable with a different one to check if it was the cable.
Uninstall printer from 'installed printers' in Windows (delete). Disconnect printer from USB, reinstall printer from printer software CD or downloaded driver. Connect printer to usb only after installing, or when explicitly required by software, this is important
Here is link to driver download, put your windows version in select OS box.
Apr 23, 2008 | Office Equipment & Supplies
23 people viewed this question
k24674
jasbo
jasbo
