Question about Canon FAX L-120 Plain Paper Laser
When I put a new toner in the fax paper always stuck, and when I put the old toner everything works ok
  • 385 Answers
It sound like the toner drum is not turning!Take the cartridge to where u bought it and have it checked!Good Luck!
Posted on Apr 29, 2010
Its always saying that BACK COVER IS OPEN we already check it for many times but its intact and in correct possition. and also the paper wont feed the machine.
Hi there!!
The message that you're getting means that either the back cover is not closed securely or there's a jammed paper inside. Here's what you can do to clear the message:
-Please unplug the fax machine for your safety -Open the front cover -Remove the toner & drum assembly (theres a handle in the center of the drum/toner assembly, just pull it towards you. -Remove any pieces of paper stuck or the jammed paper -Remove the toner from the drum and check for any other pieces of paper stuck -Once everything is clear -Reinstall the toner back into the drum and the drum & toner assembly to the fax machine. You should hear it click into place once installed correctly -Close the front cover & plug in the power cord. That should clear the message
Hope this helps, Thumbs up if it does, thanks!
May 08, 2011 | Brother IntelliFax-2820 Laser Fax
Having a clicking noise problem when installing a new toner cartridge into the fax machine. Reusing the old cartridge makes the noise go away. There is nothing wrong with the new toner (we have 2 and both...
You state that you have 2 new toners and both make a noise, but the old one does not. If both the two new toners came from the same source then it is possible that the vendor has a quality control problem and manufactured several defective cartridges. It does happen. If these are not genuine Muratec toners, that makes it all the more likely because often they are remanufactured and attention was not paid to details. Is the old cartridge from the same vendor and does it bear the same brand name if it is not a genuine Muratec item? 15 years in this business tells me that if the old one is quiet and the new ones are noisy, something is wrong with the cartridges, not your machine.
May 05, 2011 | Muratec F320 Plain Paper LED Fax
Toner empty, but i have just installed a new toner
if you toner is empty replace it.
if you replaced it and it still say emty do the following
  • menu
  • 1
  • 9
  • 4
  • 3
you will go in service mode.
look for ignore toner put it on.
if it still not working open the fax take out the cartridge. you will see ontop of the cardrige is a fuse. put a new on in put cartrige back. close the door for 5 sec. and take cartrigde out and remove the fuse. it should work then.
Feb 08, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Intellifax 2800 does not register new drum. I put in new drum and it is extremely light copies and is stll telling me to replace drum soon
If you replaced the drum with a new one, then a special plastic piece with slots in it will be ejected. This will reset the "Replace Drum" message. Now the light print is probably due to the toner needing replacing. When you put in a new drum, it needs new toner too. Unfortunately, most people replace the toner into the old drum, which does no good and becomes wasted. NEW DRUM NEW TONER. Now if you have replaced the old drum with another old drum, you won't get the reset done properly and the new drum won't load any toner either. Perhaps you accidentally removed the plastic sheet when you replaced the drum? Well then, find the piece and run it through the paper feed, it will then reset. Best of luck
Oct 06, 2010 | Brother IntelliFAX 2800 Laser Fax
We have an old 9920 PB fax machine and it is no longer under warranty and when our fax receipts come out they have ink on both sides of the paper. I mean extra black toner. Not coming out clear. how much...
Your toner cartridge is leaking because all of then now are refills.
If you decide to put $200 into it for a new cartridge, remove the swinging shield that covers the drum before installing it.
it will come loose and cause paper jams.
Dec 02, 2009 | Pitney Bowes 9920 Plain Paper Fax
Samsung sf5100 fax How do i replace the toner
Open front cover,then pull out toner and in the middle you will see a tiny fuse. Take it out and put a new one in. Put back toner,close everything and let it run.
Sep 11, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Replaced toner but continues to say replace toner&power failure 8
Anthony here. Had a similar problem, fax didn't detect the new toner. The photo sensor does not detect the toner en the fax is new. Put a black tape where the toner slots into the sensor en walla it worked. When the copies become faint I know that the toner is low or over.
A.K (Nairobi, Kenya)
Jul 10, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Canon 2060p message check/cover paper
there is a little white piece of plastic that gets stuck when you put in or take out toner catridges when not in the right position it cause that notification thank you again
Oct 14, 2008 | Canon LaserClass 2060 Fax
PAPER JAMMED
You have a stuck sensor.
Open the rear door and make sure there is no paper in there.
Remove your toner from the drum and make sure there are no bits of paper stuck under the toner cartridge.
l
Look inside the drum chamber for the little plastic levers that actuate the sensors. Make sure they move back and fourth freely.
Dec 05, 2007 | Brother IntelliFAX 4100 Laser Fax
Canon FAX L-120 Plain Paper Laser Logo
37 people viewed this question
old marine
old marine
