Question about Frigidaire FEQ1442ES Electric Dryer
Keep getting 3 beeps and the lights come on while its beeping.
The dryer keeps beeping while it's running or not 3 beeps and all the lights come onwhile it beeps. How can I reset it?
  • 7 more comments
  • Anonymous Mar 25, 2008
    I have the same problem how can I fix it
    Thanks
    Woody
  • noliaman265 Jun 14, 2008
    I have the same problem. I live alone,came home one night and my dryer was beeping and all lights were flashing.
  • Shannon Jun 25, 2008
    My dryer is doing the exact same thing. Originally, it would only do it a couple of times but now. it does it the entire time it is on. Its driving me crazy... I do alot of laundry and that makes for a lot of beeping.
  • Anonymous Jul 06, 2008
    Close..the lights come on the dry/presssaver etc row and flash/beep a few times, also the lights come on and it beeps when not using the dryer
  • Anonymous Sep 23, 2008
    Three beeps, light flashing throughout the load. It's driving me nuts too, only my model is a FEQB4000FSO.
  • swampgirl78 Sep 23, 2008
    The three beeps and lights as well, only I just bough these. They seem to be closed into the space for my washer and dryer and I am wondering if it might be the heat or the vent line is to compacted.
  • Anonymous Jan 14, 2009
    I receive different beeping action,
    sometimes I receive a series of 3 or 4 beeps and all lights on a flashing
  • Anonymous Mar 05, 2009
    This is so annoying. I won't buy another Frigidaire washer and dryer. They were the cheapest, but not the best. My washer makes an annoying buzz if it's not closed exactly right before starting.
  • Anonymous Apr 03, 2009
    I had the same problem: three beeps, and could not clear the flashing lights, even after I had cleaned the lint filter. I fixed the problem using tips from other contributers on this page - I unplugged the machine for several minutes, and unscrewed plastic framework supporting the lint trap. Sure enough, there was a tennis-ball sized pile of lint. I removed it, vacuumed out the area, plugged in the machine again, and it worked fine.
Mine has been beeping incessantly as well. Turned out that even though I was cleaning the filter after each load, there was still a ball of lint the size of a tennis ball that was blocking the lint sensor. To fix, I removed the screws from the plastic piece that holds the lint trap and slid it out (it won't come out entirely.) Then I used the mini attachments for my vacuum to remove the lint from the bottom of that space. Once I did that, the dryer has been working flawlessly.
Posted on Mar 22, 2009
  • tash9 Oct 06, 2010
    This worked for me too... when I removed the plastic piece the inside was full of lint, triggering the sensor.
  • Anonymous Aug 04, 2015
    Did not work for me at first. After fully cleaning the lint out, it kept beeping in 3s. After running it for 5 minutes, the beeps went away.
Have you tried unplugging the dryer for a few minutes. It might make the computer reset. It seems to have helped with mine.
Posted on Jun 25, 2008
I did the lint cleaning too and the beeping stopped! Eureka! Thanks!
Posted on Nov 05, 2012
Mine was doing that constantly. The repairman told me to buy a new one because the circuit board has gone bad. Suggestion. Buy another brand.
Posted on Jul 07, 2008
Frigidaire electric dryer (FEQ1442CES) keep flashing and beeping even after cleaning lint filter.
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, keeps beeping and flashing lights. I also see that you have cleaned all the lint out and your appliance will not run more than about 10 seconds. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the lights to flash and the beeping, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire FEQ1442ES Electric Dryer
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Anti crease light flashing, keeps stopping and beeping
Check the dryer vent to see if it is free and clear.
Jan 26, 2014 | Miele Dryers
My Frigidaire FEQ1442ESO Dryer Keeps beeping (6) beeps at a time & turns itself off after running only 18 seconds so I cannot dry anything and the only way to stop the beeping is to unplug it, do you...
Unplug it.
Remove the 2 screws on the back side to get the top off.
Slide the top off and take the 2 control panel screws off lift up the control panel and get he tech sheet out. Consult it to find out about them beeps. Use this LINK to access service videos for your machine.
Sep 30, 2010 | Frigidaire FEQ1442ES Electric Dryer
I have a Kenmore elite dryer, and the signal cycle keeps beeping and the light switches from on to off with every beep...it does it about 6-8 times then may wait 20 seconds to 5 mins b4 it does it again. ...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 09, 2010 | Kenmore 67082 Electric Dryer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer keeps beeping
the beeping is an indication of a problem with the drier, you are going to need a reapir person to look at it, until the problem is fixed the beep will continue.
Aug 26, 2009 | Kenmore 67082 Electric Dryer
3 beep-tones
I am having this same problem, and it seems quite intermittant. I have finally narrowed it down to an electrical issue, somewhere on the control circuit board (which I have sitting in front of me right now.) I'm going to see if I can buy a new one, and for how much, before calling out the repairman.
Mar 16, 2009 | Frigidaire FEQ332E Electric Dryer
My dryer keeps beeping after 30seconds of turning it on. I have pressed the 'LOCK' key to unlock & even then it still does the beeping thing! Could this be the motherboard packing up?
I had the same problem. My wife was about to take an axe to the darn thing. The frustrating thing was that it was beeping 3 times and the status lights were flashing. The manual only described 4 beeps (Dryer ran too long) or 6 beeps (Push button does not function). It finally dawned on me that it was beeping two sets of three beeps (i.e 6 beeps). The corrective action was to press buttons lightly and release. I pressed on every button first lightly then heavily with no success. I pounded on the instrument panel; still no luck. Finally I pressed the Options button and the Select button simultaneously for a second and heard a click. After that, no more beeping. According to the manual this activates a "LOCK' feature if you hold them down long enough. But in my case, the lock light flashed but didn't engage and after the beeping stopped, I left well enough alone.
Hope this helps.
Jun 22, 2008 | Dryers
Frigidaire FEQ1442ES Electric Dryer Logo
4,303 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
