The Kyocera FS-C5100DN printer is saying add toner but not which1
The FS-C5100DN printer is saying add toner but not which toner. As this is the first time we have had to replace the toner, we would appreciate some guidance
ebenezer
  • 25 Answers
SOURCE: Kyocera Mita FS-3800
hello helpless try to clean the printer from smeared tonner and the transfer. the grey print could be as a result of printing using application sofware. make sure the tonner economy mode is not active form the application software,if it was turn it off and save, then reprint.
Posted on Aug 11, 2007
leroyal
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
SOURCE: How to scan from Kyocera
There is a send button on the left of the control panel. after pressing send, use address book, and chose where to send to....obviously your address book must be setup first
Posted on Mar 15, 2010
SOURCE: Hi, moved my FS 3830 and it now says check waste
If you are in Ho Chi Minh City,you can go to Dinh Cao Trading and Service Company at 63 Vinh Vien street district 10 and we'll solve the problem for you.
Posted on Mar 16, 2010
Testimonial: "We took machine there this morning. Will lwt you know how it goes..."
Kyocera FS-C5100DN shows Error message "close front cover" what to do??
it is in the left front of the machine the cover you open to change toner should have a actuator that pushes the switch that could be broken off or 1 of your toner cartidges may not be set correctly remove all of them and close the cover if it says install toners do that 1 at a time see if it keeps saying install cartriges until all are installed or you see close cover message after 1 is installed that would be the 1 not installed correctly causing your close cover message
Mar 29, 2017 | Kyocera FS-C5100DN Color Laser Printer 23...
Wont operate because display says 'close top cover' even though it is closed.
If you remove the toners you'll see a little lever usuall has a yellow sticker attached that can be pushed forward or back make sure it's pushed towards the back of the machine then reload the toners and close
if it still won't close you may have broken the actuator off the lid that pushes the switch when the closes
Mar 15, 2015 | Kyocera FS-C5100DN Color Laser Printer 23...
If you remove the toners you'll see a little lever usually has a yellow sticker attached that can be pushed forward or back make sure it's pushed towards the front of the machine then reload the toners and close
Why is the kyocera fs-c5100dn print smudging
If the final product is smudging after it prints out the fuser unit is not working and the toner is not fused to the paper. Also the paper should be warm when it prints out.
If it is during the printing you may have loose toner in the printer that is contaminating the print process.
Aug 29, 2014 | Kyocera FS-C5100DN Color Laser Printer 23...
Kyocera service codes
Magenta developer unit non- install-
ing error
• The toner sensor 1 inside the magenta
developer unit did not output the den-
sity detection signal, judged the
engine controller PWB (KP-1054) the
magenta developer unit is not
installed.
You may want to leave that to a certified tech!
Aug 29, 2014 | Kyocera Office Equipment & Supplies
I have a kyocera fs-c5150dn and it keeps saying check the toner container what does that mean
check the waste toner bottler or the other toners reset in machine then reboot
May 01, 2014 | Kyocera FSC5150DN Laser Printer
Error on display call service 7402:0005942
The machine is not detecting the cyan developer unit . I would first try reseating the unit or replacing it.
Jan 29, 2014 | Kyocera FS-C5100DN Color Laser Printer 23...
ERROR CODE F186 FOR KYOCERA FS-C5100DN
Guten Tag,
Kyocera FS-C5100 error code 186
was sagt der fehler aus
Aug 06, 2013 | Kyocera FS-C5100DN Color Laser Printer 23...
I have a Kyocera FS-2000D i've installed a new toner kit, but the printer is stuck on saying "please wait" adding toner.
Turn of the printer unplug and then turn back on.
Was the toner you installed a Kyocera toner or a after market toner? If it was an after market toner that could be your issue.
Feb 12, 2011 | Kyocera FS-2000D Laser Printer
We have a kyocera fs-c5100dn. When printing credit card reciepts it takes around 1.5 minutes. Is there some way to speed this up?
The printer probably is going into "power-saving" mode after several minutes of non-usage. Then, it must "warm-up" for 90 seconds, in order to print the page. Reconfigure the printer to stay "active" for a longer time, like 30 minutes, before entering "power-save" mode.
Sep 01, 2010 | Kyocera FS-3900DN Laser Printer
272 people viewed this question
jasbo
jasbo
