Question about Sharp AR-5320 Black and White Copier
HOW TO RESET CAL SERVICE MAN AND TO RESET DEVELOPER
Posted on May 12, 2010
    Problem Solver:
  • 9 Answers
Does the machine stop or cannot run any copy job anymore?...if you still can copy, never mind the warning. but if you cant print anymore, then you really need a service man...
Posted on Apr 29, 2010
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
Developer light on
'Service man:press # interupt and C interupt
enter 24 and then 01 for drum and then 42 then 01 for developer.
Mar 22, 2014 | Sharp AR-5316 Advanced Digital Imager...
We no longer have our manual. The Little man is lit up and also the dotted circles to the right of the triangle. What does it mean?
the little man means time for service, that is replace the drum and toner developer units,
the maint. man has to be reset by aservice tech, you might try the sharp support site for the reset instructions .
good luck ,tinyman
Jul 19, 2011 | Sharp AR-153E Copier
A) Developer signal is always showing after replacing developer.How can it be solved? Man signal is always showing. B) New toner has been replaced but also it is printing light.
A) To reset developer signal press: # key __ interrupt key __ C key __ interrupt key __ 42 __ ready __ 1 __ ready . and you may have to check program 41 for developer counter cycle
B) check the developer
Dec 16, 2010 | Sharp AR-5316 Advanced Digital Imager...
The machine is showing service man and developer
That means that the drum & developer needs to be replaced. It depends on you? You will also need to reset the counters. Also, you can turn those warnings off in service mode.
Sep 15, 2010 | Sharp AR-M205 Copier
I have been using sharp copier- table size(SF-2218). but recently a red image in form of a man is viewed which is stopping the copier from warming up.
Dear sir; The symble of red man, means need PM service, you need to replace DEVELOPER,
slide out developer unit and remove toner hopper(2 screw),Empty old developer,replace with full bag, reassemble, install back to the machine. power on, press "clear", "pause", "0", "pause" keys, then enter 25, press print, enter 2, press print,machine will run for 3 minutes, the "pause" key also call "interupty" key, when machine stop then press "clear" then enter 20 press "print" enter 01, press print, enter 0, then press clear key enter21 press print enter01 press print,enter 0, press print press clear twice to end the simulation.
If you not clear or need more help just email me, I always around, good luck!
DON'T FORGET GIVE ME A RATING
HAVE A HAPPY HOLIDAY !!!
Dec 22, 2008 | Office Equipment & Supplies
Sharp AR 407
You will need to get some developer.  Usually you can get it from who you get your toner from.
Remover all developer out of the cartridge using a vacuum.  Carefully remove all developer off of the mag roller as well.
Install developer evenly into the cartridge.
You will need to run a service code to initialize the developer and reset the counter.  If this isn't done properly, the developer will get contaminated and have to be removed again.
You should obtain a service manual for step by step instructions on how to replace the developer for your particular copier.
Nov 11, 2008 | Office Equipment & Supplies
Sharp ar5320 developer reset code
The developer doesn't have a reset code.  It uses a calibration program instead with the reset integrated into it.
Even though the copy quality is fine for now, it can change in the next few days.  You should order some developer.
Sep 16, 2008 | Office Equipment & Supplies
Developer sign
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Aug 11, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 Black and White Copier Logo
472 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
