Question about SanDisk Sansa m240 MP3 Player
T please wait rebuilding the library wont come off screen on sansa m240
  • 758 Answers
I would recommend that you update the firmware on your device..that usually solve the problem you are having...to update the firmware follow the link below..
http://www.sandisk.com/DriverDownload/download.asp
I hope that helps
Please rate accordingly
Thank You
Computerrep
Posted on Mar 25, 2008
SOURCE:
Delete files or clear music files off disk to rebuild music library.
plug it into your cpu then go to my computer select your mp3 player and open it by clicking on it then go into your music files and delete what you do not want on it it is a very easy drag and drop style mp3 player
Nov 18, 2009 | SanDisk Sansa m240 MP3 Player
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your sansa...you highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m240 problem
To format the player directly, follow these steps:
1. Press the Home button to return to the Main Menu.
2. Select Settings from the Main Menu.
3. Select System Settings.
4. Scroll down to Format and select it.
5. Select Yes to start formatting.
Aug 21, 2008 | SanDisk Sansa m240 MP3 Player
Synching songs to Sansa m240
YOU MIGHT NOT HAVE SYNCED RIGHT....YOU MIGHT NEED TO DRAG AND DROP YOUR FILES OR CONSIDER GETTING A SANDISK E200 OR A CX00 VERSION MP3 THEY ARE MUCH EASIER TO WORK WITH
Feb 20, 2008 | SanDisk Sansa m240 MP3 Player
Synchronize my m240
The "please synchronize" error refers to the license for the library audio book you have on your device.
You will need to contact the content providers to troubleshoot the license issue.
Best of Luck.
Oct 15, 2007 | SanDisk Sansa m240 MP3 Player
Problem with my MP3 player...
I am having the same issue. I loaded my M240 with music, then umpluged it from the USB cable. It didn't do the "building library" thing like it always does, and now when i turn it on it just loops from the "Sandisk" startup screen to the "Sansa initiallizing" screen. The same as you, when i connect it to the pc it isn't even recongnized and the player loops the "initiallizing" screen again. I put a request in to Sandisk last night, so i might have a solution for us later today.
Jun 15, 2007 | SanDisk Sansa m240 MP3 Player
Reset button
This is a well know fault with the m240. The easiest fix is to take it back to the store you bought it from and get a replacement :)
Jun 12, 2007 | SanDisk Sansa m240 MP3 Player
Please Wait, Rebuilding the Library
GOOD LUCK!! i am soooo frustrated with these little **** players. my old Discman is looking pretty good at this stage. at least it was straight forward!!.
Feb 27, 2007 | SanDisk Sansa m250 MP3 Player
Freezing
Thank you for contacting SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product through your recent inquiry into our product line. We do apologize for any kind inconvenience this issue is causing you. For verification, does your computer have Windows XP as its operating system? This issue may be due to some sort of corruption on the Sansa m240 itself. We should try formatting the Sansa m240 as a possible solution. Caution: Formatting will erase all information on the Sansa mp3 player. Please be sure to have a back up of all the information before proceeding. If your Sansa m240 is currently frozen, please remove the battery (to unfreeze it), then put it back in, and connect it to your Windows XP computer. Since you cannot access your Sansa m240 to convert to MSC mode, please have the ?HOLD? button ?ON? so that you can have your Sansa m240 in MSC mode before plugging to your computer. To format the Sansa m240 on your PC, let us connect the Sansa m240 to your computer on an USB port preferably located near the power hub or to an external self powered USB hub, go to ?My Computer?, single right click on the ?Removable Disk? associated with your Sansa m240, and select ?Format?. Let us please make sure that, under FILE SYSTEM, we change FAT to FAT32, and then single left click ?Start?. This will erase all data off the Sansa m240 and correct errors on it, which should make the Sansa m240 usable again. We also recommend formatting the Sansa m240 another way. Please be advised again that formatting will erase all data. Please right click on my computer and select ?Manage?. When ?Computer Management? comes up, please click on ?Disk Management? on the left hand side. After clicking on ?Disk Management? you should now have a list of drives in the right side panel. On the right, look for the Sansa m240, it may show up as Disk 1, 2, 3? Removable Disk. Right click on the larger "Volume" rectangular icon to the right of the Removable disk and select ?Format? choosing FAT32. If you do not have the format option, please select "New Partition" and just keep clicking next through the Wizard that appears. After formatting the Sansa m240, please do try your Sansa m240. If applicable, please go the link below to download the firmware update for your Sansa m240. The link is: http://www.sandisk.com/Retail/Default.aspx?CatID=1326 or http://www.sandisk.com/Retail/Default.aspx?CatID=1376 If formatting and firmware update in your computer is not possible, please do try the process again on another Windows XP computer. NOTE: Please be aware that formatting is a normal and necessary method of drive maintenance and repair, and simply NOT formatting periodically can cause a drive to slip into failure due to the backup, and clutter of residual data.
Dec 27, 2006 | SanDisk Sansa m240 MP3 Player
Problem with Sansa m240 1GB
Try formating it from your desktop
Aug 03, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
146 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
