Question about Dometic RM2193 Compact Refrigerator With Ice Box
Hi (Help Please) My Dometic 3 way fridge is not cooling when on electric,but it is on gas. i have had a new element fitted but still wont cool when on electric, any other thins i could check???
    Habit-Forming:
  • 193 Answers
Heater element,
power transformer
thermostat
change over switch if fitted
Posted on Apr 29, 2010
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
Dometic RM 3662 not working on gas or AC power. I've changed the heat element, I can see the flame of the burner. What's going on that the unit won't cool off. Tried gas for 5+ hours and the fridge seemed...
When running on Electric insure that the rear coils of the cooling unit are getting warm. If the refrigerator is level and the coils are warm and the refrigerator does not cool then you more then likely will require a replacement cooling unit. I have attached a small video that may help with the diagnoses. You can also give us a call toll free 1-888-782-6665 ArctiCold Refrigeration We keep it cold
Aug 27, 2013 | Dometic Refrigerators
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
Hi,i have chescold rt50 fridge freezer,older model,colourbond brown colour,recently i have replaced the 240v element and the fridge work perfect again,at last camping trip i used on gas and work icy...
try disconnecting thermistor let run if cold replace thermistor if not bad board or cooling unit look for yellow stains on cooling unit or if you smell ammonia
Oct 13, 2017 | Dometic Refrigerators
I have a dometic dm2652 rv fridge. its new and is
The DM2652 comes with an optional cooling fan to help with cooling the amonia. The fan cycles on and off as required as it has a tempeature sensor (thermistor). We turn ours off at night by removing the inline fuse (glass tube fuse 3 amp) located in your outside acces panel. The fuse is located in a black fuse holder with a re wire connecting both sides.
Jun 06, 2010 | Dometic RM2652 Refrigerator
Work on gas but not on eletricity
More than likely the AC (hydro) element is defective. Take a multimeter and carefully test for 120vac at the 2 spade connectors that the element plugs into on your circuit board. If your getting 120vac, then element is probably shot. ( element can be removed by lifting and twisting it up and out of sleeve along side of stack) be sure it's cool to touch. You may also have to remove, or reposition metal flap over it prior to removing. Make sure when testing for voltage at spade connectors, that fridge is calling for cool.
May 03, 2010 | Dometic RM2652 Refrigerator
My 3-way Dometic fridge works on gas but stopped working on 240V! ....Why?
With the 240V element diconnected, test it with an ohm meter to find it was open circuit. No heat! The 12v element still had resistance.
At the moment gas is still keeping my cool while I wait for a new element to arrive. ..... cheers
Sep 01, 2009 | Dometic RM2652 Refrigerator
Freezer working on gas but not fridge compartment.
Check to see if you have the right gas pressure at the refer
Jan 26, 2009 | Dometic RM2652 Refrigerator
New Travel trailer......no fridge!
Unit should still be covered on warranty call dometic directly. The tilting could affect some. If you push the auto button in it should run on electric first if no electric present it then goes to gas. Exception to the rule is if the heating element is not working it does not recognize this so it will stay on electric. Unplug the 110v in the compartment on the outside it should change to gas with in a few seconds. If it does heating element is bad.
Aug 18, 2007 | Dometic RGE400 Top Freezer Refrigerator
Dometic RM2193 Compact Refrigerator With Ice Box Logo
469 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
