Question about Jenn-Air JES9860 Electric Kitchen Range
I have a jenn-air model# jes9900bab, the key pad is not working at all.
4 Suggested Answers
SOURCE: PUSH PAD DONT WORK RIGHT.
follow up to the above by Kaseymoe - the solution was replacement of the Membrane Switch Assemble - what I'd call the touchpad. It's the entire, full width front of the over controls - white panel with the oven controls.
I was able to get a replacement from Marcone - a parts distributor. Sine I read here that his is a repeat problem i took out Marcone's Lifetime Warranty. That cost an extra $24 but if the part ever fails again and no matter how many times I've alread paid for the next and the next and the next panels so that's good.
All access is from the front panel - look under it to remove 8 screws then I had to slide the entire range out from the counter to remove the side triangular trim pieces and get access to the panel. Knobs and computer module come off the original panel and go on the replacement. If you're not got at remember which screws go where make a sketch and keep track of the disassembly. It's reasonably straightforward but i managed to have to do parts ot it twice in the reassembly stage.
The part was $161 from Marcone in Nov 2008. The optional warranty $24.
rjw in Kansas City MO
Posted on Nov 26, 2008
  • 11 Answers
SOURCE: The touch pad on my Jenn Air Model JES9800BAF does
All burners work fine, clock display is blank, if the oven isn't working either, your display / control board is shorted out
Posted on Nov 13, 2009
heatman101
  • 43501 Answers
SOURCE: My Jenn-Air range was delivered several months ago.
here ya go...
http://www.ajmadison.com/ajmadison/itemdocs/JES9900BAS_Use_and_Care.pdf
heatman101
Posted on Apr 25, 2010
Testimonial: "Yes your feedback was right on. I simply cannot believe that the company who makes Jenn-Air expects their consumers to print out their own instructio"
Jenn air downdraft
replace parts only. no home fix on these. Depending on model #, the parts may no longer be available, but you can always search on ebay for one.
Aug 18, 2014 | Jenn-Air Kitchen Ranges
Jennair oven: control lock
You should be able to depress and hold the #1 key till the control lock turns off. Pleazer Appliance...
Mar 22, 2014 | Jenn-Air Kitchen Ranges
Error code SAb bath on Jenn Air oven. Held clock button down for 5 seconds and key pad still will not work.
possible need new key pad.first check no loose connection from key pad to the control board,if not replace key pad
Nov 24, 2013 | Jenn-Air Ovens
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
The Jenn-Air Gas Range Electronic touch control 800. The key pad does not work. You can not set the clock or work the oven. Help.
My Jenn Air has the same problem with the computer touchpad. The only temperature I can get to work is from the left hand column, 411 degrees. I don't want to waste another dime on this oven. I've read so many complaints from other owners. No more Jenn Air products for me.
Nov 22, 2010 | Jenn-Air Ovens
Jenn- Air cook top oven sve47500b has error # F7 and the oven will not work
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Oct 25, 2010 | Jenn-Air JED8430 Electric Cooktop
My oven was beeping with a code of FO. Do you know what that means? It's a jenn air oven.
HI. This code will appear when one, or more of the function keys on your unit has failed. If your control board has the key pad integrated into the main board(combination design), simply replace the entire control board. If the unit has a separate control board, that is not combined with the key pad, simply replace the key pad.
Nov 27, 2009 | Jenn-Air Ovens
Jenn-Air JES9900BAB Electric downdraft range with convection oven
sounds like the power outtage fried the clock. unfortunately, none of today's ovens come with a UPS (uninterruptible power supply), sort of like a power box for your computer. if he power goes out, it'll fry the electronics, including the clock.
have a technician come out and test the clock to see if there is power going to it and what voltage is coming out of it. i would suggest replacing the clock.
Apr 05, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air Wall Oven up controls don't work
you have a touch pad issue, whats the model and serial ill look up the part for you, sometimes you can just get the key pad, sometimes comes sa a whole console or as part of the electronic control itself.
Mar 17, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air JES9860 Electric Kitchen Range Logo
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
