Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How do i change the ink cartridges on my epson stylus dx7400
  • 242 Answers
It is as simple as below.
Open up the hood of your printer.
Switch on the printer.
The cartridge will come in the centre to remove.
Press at the back of the cartridge and slowly remove it.
While installing the new one follow the reverse process.
Thanks
Jimmy
Posted on Apr 29, 2010
SOURCE: EPSON DX7400 ALL IN ONE PRINTER INK CHANGE
ok just done it - i always have to look it up too!
find the default printer from your control panel
click right click and pick properties
then hit printing preferences
then click tab marked maintenance
and follow the ink cartridge replacement instruction
printer leads you through no probs - hope this helps
Posted on Apr 25, 2009
Remag1234
  • 387 Answers
SOURCE: how do I change the ink cartridge on a Epson
Directions are on the Inside the cover and in the manual, you can also find them at the Epson website.
Posted on Dec 29, 2009
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
SOURCE: Epson Stylus DX7400 - Ink cartriges
Dead easy if you follow these instructions:
Click on "Start" and select "Control Panel"
From Control Panel, select "Printers & Faxes"
Right Click on "Epson"
Select "Printing Preferences"
Select "Maintenance"
Select "Ink Cartridge Replacement"
The cartridges will now be easy to remove and just follow remaining instructions on screen.
Posted on May 10, 2010
  • 4 Answers
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Posted on Oct 25, 2010
How to replace an ink cartridge on Epson Dx7400.Cyan has run out TO712.I have lost my user manual and I cannot remember which button to press to get the Printer part to the right spot for changing the...
On your printer and then click on the start menu goto Printer and Faxes. After that goto your default printer Epson Stylus and right click the printer then click properties. Dialogue box was appear click on the maintenance and then click replace cartridge their was dialogue box will also appear. Just click the next button and read the instruction when you press the Next button. After that open the cover of your printer when the cartridge are at the center thats the time you can change the cartridge. Then close the cover when your finished to change the cartridge. Then click the next button and so on to finished.
May 28, 2010 | Epson Stylus Multifunction Inkjet Printer/...
How do I change the ink cartridge on a Epson DX7400
Dec 29, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Replacement ink cartridge ruined my printer.
Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Mar 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson dx7400 printing green
one of your people advised me that it was most likley a bad cartridge i changed it and it worked ,thanks
Feb 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Changing inks
Visit this page and download the manual for your printer: www.techfuels.com/printer/11727-epson-stylus-dx7400-all-one-inkjet-colour-printer.html - 53k -
Jan 23, 2009 | HP Compaq Business Desktop dx7400 - Core 2...
Epson DX7400 only printing Blue + Black
I'm sorry you have received no response on this , it's probably because you have posted it in the C86 printer group rather than the DX7400 group. I presume you have now solved this problem. If not, please re-open it (in the DX7400 group) for help.
Dec 15, 2008 | Epson Stylus C86 InkJet Printer
Lift the scanner up to expose the inside of the printer. Thers a button "stop" top left face of printer, press and release and the print cartridge holder will move, press again and it will stop at the colour that needs replacing, press again (total four times) to show if other cartridges are ok. Press again and the cartridge carrier will return to right of the machine. Lift the lid (grey colour) to show the cartridges, remove and replace the ones that have been shown to be empty. Close the lid, it should click. Close the scanner down again. Press "start" to recharge the cartridge. ANy other problems try the epson support site. Good luck.
Aug 31, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
200 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
