Question about Foxconn K8M890M2MA-RS2H Motherboard
My usb ports are not recognized by the sistem though are receiving power (I chargerd a mp4 player).
  • adis_tha_pla Apr 29, 2010
    fixed it....it was a BIOS setting problem. Don't know what it was. I used restore defaults and then usb controller tree was found at the log in. Thanks Hannibalwr....you've been a great help
    Scholar:
  • 99 Answers
Xkchgxkjchgx
xgvxkljcg
xgvxo
xgfcj
Posted on Apr 29, 2010
Connect mp4 player to usb
USB ports on car stereos are not designed to be universal, regardless of what the USB acronym implies. They are typically designed for a specific product, either iPhone, Android, Blackberry, or a combination of those. They usually work with a blank flash drive (no operating system on it). That would be my recommendation: Buy a flash drive. $5-$10 invested will probably get you more storage than the GoGear and will work with USB.
The reason USB sounds better than the auxiliary input is because with auxiliary, the D-to-A (Digital to Analog) conversion is done by the GoGear, while with USB it is being done by the car stereo.
Dec 20, 2013 | JVC Car Audio & Video
Mp4 player not working
Check your MP4 player's system requirements.
Some MP4 players are only capable of working with certain operating systems and hardware, so refer to your player's documentation to ensure it is capable of functioning with your PC.
Change the USB port your MP4 player is connected to if you have confirmed your PC can function with your MP4 player.
Disconnect other USB devices, and try connecting your player to another USB port if you are still having problems.
Try restarting your PC if it is capable of working with your MP4 player.
Restarting your PC resets non-functioning USB ports, which may be your problem.
Make sure your USB cable is connected properly.
If your player requires you to install drivers, make sure you install them.
Try connecting your player to another PC to see if the new PC recognizes it.
If it does, chances are your computer does not support the hardware necessary to run your player.
Reset your MP4 player if your PC is still unable to recognize it.
Resetting your player varies depending on the manufacturer and model, so refer to your player's documentation.
Contact your player's manufacturer if you are still unable to get it to work with your PC.
http://applestore.altervista.org/mp3mp4.pdf
Aug 25, 2013 | Intel Computers & Internet
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
I hav got a cyberview mp4 player from singapore.when i plug to my comp to copy songs from it , thrs a msg sayin tat us b device not recognized..i've tried restartin my comp nd even reinstalled my usb...
try connecting it to the other USB ports and install the driver. It can help sometimes. if it is not working even when you reinstall the driver the device might be dead.
Mar 05, 2011 | Audio Players & Recorders
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
4. Power issue.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
STEP 1 - Connect the Sansa player to the PC
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
How do I download music onto my MP4 player please?
You should have received a data/charging cable with it.
Plug it in to a USB port on your computer.
The computer should recognize it as an external data device like a thumb drive, and you can copy music to it.
The computer may need a driver to tell it what it's looking at, and if one is required it is usually provided on a CD that came with the player.
Dec 28, 2010 | Laser MP4-V970 MP3 Player
Usb not recognized on sansa e280 (sandisk)
Unfortunately, so simple - although this simple solution does not appear in any manual. the solution: put your Sansa in the rear USB - and the PC immediately recognizes the MP3 or MP4. The USB soccket in the front of the PC does not have enogh power, and when using the rear USB port - it works!
Izi
izimann@lycos.com
Apr 04, 2008 | Audio Players & Recorders
Mp4 player
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Dec 26, 2007 | iLO (2 GB) MP3 Player
Computer Won't recognize MP3/MP4 Player
Go to device manager. Remove all USB ports. Re-boot. See if that workds.
Dec 20, 2007 | Samsung YP-T8 Digital Media Player
Foxconn K8M890M2MA-RS2H Motherboard Logo
128 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
