Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Will not spin and has a burning rubber smell
Everytime I try to use it I get no spin then after while a burning smell of rubber. How do I change the belt or get it to spin again.
Ken ([email protected] or [email protected]
    Genius:
  • 3,587 Answers
Sounds like a loose belt, or worse, a stuck pulley..
tip the unit back about 30 degrees, with power off, and unplugged, and inspect the belt..I suggest something solid to hold it up(not your hand or someone elses)...and see if you have free play there, or it's frozen
Posted on Mar 24, 2008
SOURCE:
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Smells like burning rubber when running
Vacuum belts lose elasticity and will slip. It may spin the brush roll ok when you look at it but be so loose that when. Vacuuming carpets the belt will stop turning. The motor shaft is still spinning and will melt the rubber belt causing a burned rubber smell. Belts on almost All vacuums need. To be changed at least twice per year.
Nov 13, 2011 | Riccar 8955 Upright Vacuum
Smell rubber burning when on spin cycle
This sounds like the belt is slipping, which will burn the rubber and give you that smell. Replace the belt and be sure the tension pulley spins easy.
Jan 07, 2010 | Westinghouse Washing Machines
Washer wont spin, smells like burning glws1649
Burning smell could be the windings in the motor. Better not to use it and have it looked at. If the smell is a rubber smell then the belt is jammed while the motor spins. still needs intervention as it can catch on fire and you will have a bigger problem than the one you have now
Jul 31, 2009 | Frigidaire Washing Machines
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
What is the smell and does it have to be fixed?
A burning rubber smell under the hood might be just that - consider having your accessory drive belt inspected, as it is possible that a bearing in one of the accessories (alternator, power steering pump, air conditioning compressor, etc.) or in the tensioner mechanism might be failing. This sort of fault will often cause that particular accessory bearing to spin less freely than the others, and as a result the belt continues to pass over the associated pulley at the same speed as the engine. Essentially, the result is similar to a car spinning its tires on dry pavement - and a similar 'burning rubber' odor is the friction and heat of the rubberized belt.
If the odor is more like burning oil than burning rubber, the rear valve cover gasket is situated in a place that results in dripping oil, even small and unnoticable amounts, onto the exhaust manifold that is directly underneath the valve cover.
These two items might be places to start your inquiry. Best of luck to you!
Apr 16, 2009 | 1998 Lexus ES 300
Your washer has brake problems you need a qualified repair person
Apr 02, 2009 | Washing Machines
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
132 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
