Question about Motorola Mobility L6 Cellular Phone
No sound incoming & outgoing
can you pls help me that my mobile has no sound
I forgotten my phone barring password That's why has been Blocking my incoming outgoing call. How can i solve that problem. please kindly help me. Thanks
What is your mobile and model ?
If you forgot the security code you have to reset you mobile....... Its the only way to use your mobile again. After resetting you can enter a new security code again.
If you use nokia or alcatel mobile means just visit here Unlocking4u.com for the master reset code service and get the reset code........
Apr 05, 2012 | Cell Phones
I have a mobile of spice model no m4330 .from todaymy incoming calls are barred .if anyone dial my number it answeres that the number is busy . my outgoing calls are running smoothely.pls help me to break...
To cancel bared incoming calls on your phone, enter one of the code given below.
##67#, ##21#,##62# or ##61# then okay/send/yes. the phone will be unbarred.
Regards
Jun 25, 2011 | Cell Phones
Dear sir/Madam, I want the incoming and outgoing call details to my Airtel prepaid number is 09878201121. I need 01-02-2011 to 15-02-2011 incoming & outgoing call list. please send me that on my...
Dear sir/Madam,
I need 01-02-2011 to 15-02-2011 incoming & outgoing call list. please send me that on my above e-mail address is kumardeepak7077@yahoo.com
thank you
Feb 22, 2011 | Cell Phones
I want incoming and outgoing call details of my cell number 9621010060. its a airtel network. its humble reuest please as soon as possible. my email i.d is praveen88.azadnews@gmail.com
my airtel prepaid no is 918894255042 Please send call detail incoming and outgoing last 3 months its humble request as soon as possible. my email I.D. is vnekram@Gmail.com
Sep 15, 2010 | Lands Phones
Can i get the details of calls and sms from airtel prepaid number
you can get ur calls details ask ur airtel customer support to provide you. here let me tell you if u r using post paid then there is not a problem but if ur using prepay. i have a doubt but still airtel customer can provide you all the details if they want to
Oct 30, 2009 | Nokia 6300 Cell Phone
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
My p990i didnt work with outgoing sms. . nothing more help
hi
the solution is quite simple just reach yor service provider and request for the sms settings which you will get for free as an SMS
save the settings and you'll be able to send the SMS, same goes about MMS
cheers
pls rate the solution
Jun 29, 2009 | Sony Ericsson K850i Mobile Phone
Unlocked Samusng Propel Incoming & Outgoing calls, sms, mms
you should take the phone into t-mobile center and have them assign the settings for the phone.
May 29, 2009 | Samsung Propel A767 Cell Phone
Motorola Mobility L6 Cellular Phone Logo
93 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
