Question about Ricoh Office Equipment & Supplies
LANGUAGE FIRMWARE PROBLEM
I have few unit off ricoh copier machine which is in Spain and German language.
at the user tool also they provide this two language only.
finally i found that i need to upgrade the language firmware into those machine.
can anyone help me to solve this problem?
i can't log into TESSA.
need firmware for this model
URGENTLY.
a
Aficio 1027,2027,1035,1045,2035,2035e,2045,2045e,2232c,2238c,
  • 155 Answers
Normally this is done by a technician, if you go into sytem settings, there is a language setting option, normally the second option is English, you may
give it a try
Posted on Nov 05, 2011
5 Suggested Answers
  • 393 Answers
SOURCE: how to install a new hdd on my copier Ricoh 2035
Unplug machine, unplug network cable ect. remove the 2 screws that hold the board in (top & bottom) slide assy out remove HDD and put back together being careful not to hit the HDD. Exicute SP 5-832-1 (all) to initilize the HDD exicute SP 5-853 to reload stamp data. ( to enter service mode in sequence hit clear modes 1 0 7 stop, hold the stop for 5 seconds enter copy SP ) -Carl
Posted on Jul 13, 2009
  • 990 Answers
SOURCE: Ok WHile I waited for the reset directions I took
Hello sir; I don't know what's the problem of the machine, anyway I can give you reset procedure; Press "clear/mode" "107" and press and hold "clear/stop" key for 3 sec.until screen change, then turn off the power and back on again.
Posted on Nov 14, 2009
  • 2072 Answers
SOURCE: what is error code sc548
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Posted on Jul 19, 2010
  • 21 Answers
SOURCE: Sc 990 ERROR PROBLEM ON
replace drum, drum cleaning blade,charge roller. this will sort Sc 990
Posted on Oct 21, 2010
I have a dsm 627 whose origin was spain. The display is in spanish and I want it in english. Kindly let me know if the Language is stored in the nv ram or if on the operation panel chip. How do I change it...
This model (and all the other models) allows you to store 2 different language.
Press the User tools/Counter and on the top right corner you will see the other Language stored.
If it says English just press on it and its done.
If it says anything else... well, you need to download the language firmware. For that you need a technician.
See you!
Apr 29, 2011 | Office Equipment & Supplies
I have a afico 1027 which the language available in the user tool are only german and spain. but i need english..how do i settle this problem..please mail me rds_business@yahoo.com
looks like u need english language uii need to upgrade firmware but its not something ricoh will give away. the cover is on LHS 1 or 2 screws cant remember.
1. Turn off the main power switch.
2. Remove the application cover [A].
3. Insert the IC card [B] containing the software you wish to download into the
card slot of the controller.
4. Turn on the main power.
5. Follow the instructions displayed on the LCD panel
6. Monitor the downloading status on the operation panel.
• While downloading is in progress, the LCD will display “Writing”. When
downloading has been completed, the panel will display “OK”.
• For operation panel software, the Start key lights red while downloading is in
progress, and then lights green again after downloading is completed.
$CAUTION
Never switch off the power while downloading. Switching off the power while the
new software is being downloading will damage the boot files in the controller.
7. After confirming that downloading is completed, turn off the main power and
remove the IC card.
8. If more software needs to be downloaded, repeat steps 1 to 7.
9. Turn the main power on and confirm that the new software loads and that the
machine starts normally.
NOTE: If the download failed, an error message will appear on the panel. Then,
download the firmware again using the IC card as usual.
B022S999.WMF
[A]
[B]
Mar 25, 2010 | Ricoh Aficio 1035 Copier
Convert ricoh af 1027 panel language to english, HELP
Touch "user tools/counter" button, then select "Language"
Dec 05, 2009 | Ricoh Aficio 1035 Copier
Aficio 1027 convert from german language to english provided inside user tools don have as well
sounds like you may need to upgrade the firmware and change the language in the copier.
Nov 25, 2009 | Ricoh Aficio 1035 Copier
How to convert ricoh aficio 1027 from german to english?
User manuals are available in pdf from ricoh-usa.com
Can i know the way to convert ricoh aficio 1027 copier from german language to english version?
press User Tools button. The touch screen upper right corner should be language selection (below the exit selection)
I want change the language in german (nokia6555b at&t)
you go to phone settings, language if german isnt there. the phone jst cant be changed. sorry for any inconvience
Jun 30, 2009 | AT&T Nokia 6555 Cell Phone - Black
Canon CLC 1150 ? Need to change laguage in English
hi you must have sst or service suppor tool to upgrade the firmware of your clc
Jan 10, 2009 | Canon CLC 1150 Color Copier
188 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
