Question about Philips DVP642 DVD Player
Philips DVD Player Seems Dead
Any ideas? Our Philips dvp642 dvd player won't turn on. The "on switch" just blinks. Seems like it is dead. Was a nice machine. Any ideas? We tried all the usual things, checked power etc.
Thanks.
J.
  • 3 Answers
It looks like this problem has been discussed here: "Standby light blinking."
Posted on Apr 21, 2008
Power light blinking unable to turn on
And get no display?
Probably the power supply, or some other relatively catastrophic problem happened.
If it's still under warranty call Philips tech support first, for possible replacement.
Else you're probably looking at buying a DVD player, unless you want and are willing to open it up and fix it your self (time consuming).
Jul 20, 2010 | Philips DVP642 DVD Player
My Philips dvd player model DVP642/37 is not working. The stand by/ on button flashes the red light on and off slowly and non of the other buttons respond on the machine or the remote for the dvd player...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Apr 21, 2017 | Philips DVP642 DVD Player
My dvd blink red light on batton standby/on.I can't turn on!?Any idea,please!
In most cases you need to reservice the power board, or change the damaged capacitor. This capacitor is loacated on poer supply board. Also resolder the components heated area. Hope this works.
Jun 23, 2010 | Philips DVP642 DVD Player
I have a Philips DVP642 DVD player. It has worked
First try a soft reset... unplug for 20 minutes.
Otherwise - the laser is dirty or misaligned.
A Repair shop can clean and align for about $50.
It takes specialized equipment and templates to align the laser - not something you can do on your own.
Lens cleaner discs don't work.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 27, 2010 | Philips DVP642 DVD Player
Stuck dvd and no power
I fixed this problem in my DVP642 by replacing a capacitor on the main power board where the power chord hooks in. Take the top cover off (after unplugging player). You'll be able to locate the bad capacitor on the circuit board located on the very right. Look for location marked c316 on the circuit board. A bad capacitor will be bulged up on top. The capacitor you're looking for will be a black barrel shape with an aluminum top, this aluminum top will be bulged up or leaking on the circuit board. Replace this capacitor by desoldering the two leads into the board and replacing with an identical part you can pick up at Radio Shack for a couple dollars. My repair for this identical problem was a success. The blinking light is the tip off for this particular problem on these Phillips models.
Oct 08, 2009 | Philips DVP642 DVD Player
Power light is blinking on my philips dvp642 Dvd how can I fix this?
sadly it sounds like a bad power supply. does the unit even play? It can be fixed. Try this link it is from Philips.
http://tech.groups.yahoo.com/group/philips_dvp642/message/1720
good luck :D
Aug 09, 2009 | Philips DVP642 DVD Player
Problem with starting
read on a forum that changing out c316 1000uF will fix the problem, mine will not turn on now, seems to have gotten worse over time. I will change the capacitor from 1000uF 10v to 1000uF 16v.  Look at your capacitor, mine looks like its ready to blow.  Most other capacitors on the board are rated at 16 volts.  I will be changing out the cap. to see if it works.
Oct 05, 2007 | Philips DVP642 DVD Player
Won`t play disney movies
Apparently this is a known issue. Some dvp642 players have compatibility issues with some of the Disney DVD's. A firmware update might help. There is a discussion of this at: http://www.videohelp.com/forum/archive/t317193.html
Feb 19, 2007 | Philips DVP642 DVD Player
Philips DVP642 DVD Player Logo
283 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
