Question about ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN,
Can't strat up the computer
When i press the power button on the casing, the computer not getting respond, the power suppy are ok, course i can see the light on the motherboard was on, so i just want to know, did the motherboard spoil ? need to replace a new one ?
  • 4,737 Answers
You don't need to directly go for a new motherboard, but first check/ try with another power supply and make sure you connect the Four Pin Power cable also (it's located at the right corner white in color with four female socket) can't strat up the computer - 20080703220330_05402013467_p5qc.jpg If this doesn't work, check the ram and processor if they are sat fit. Good luck...
Posted on Apr 29, 2010
My power suppy does not operate at all and I am not sure whether or not it is DOA or if it is because it does not work from the switch on the power supply. My computer is a rig that I have recently put...
You need to give closure on the proper pins on the motherboard for the system to run. The power switch on the PS will always be "ON" and mobo power delivered by the switch on the case.
Oct 02, 2017 | LogiSys Computers & Internet
No display . i had the ocmputer on and then came back about 15 mins later and noticed the display went black and now I can't get it to come back on.
Most probably it has gone into standby mode - press the power button momentarily, it should come back to life if it's this case.
Of course it may be something more serious, but try that for starters. If it doesn't respond at all, the next step would be to force it to turn off by pressing and holding the power button for 10 seconds, and turning it back on after a while.
Dec 24, 2009 | Acer Aspire 5500 5570-2609 Laptop
No power
Try this: - Turn machine off; remove power cord; remove battery. - Without battery or power cord, press the power button and hold it down for at least 10 seconds. This discharges power 'residue' in the machine [and, I suspect gremlins]. - Reassemble power cord and battery. - Restart.
Mar 19, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
GT5014 won't boot
Generally this means there is a problem with the power suppy as it is not giving a correct voltage to the motherboard to start the computer. check your fans on the power supply, make sure they start when you try to start the computer . A power suppy may be purchased and installed fairly easy. and you should spend no more than 50 dollars on the parts.
Mar 05, 2009 | Gateway GT5014 PC Desktop
Not everything powers up when I turn on my disassembled computer
remove first the power suppy. if it is 24pin power suppy, shorten pin 15/16. that is the black and green,
if the fan of power supply rotates, then the P.S. is ok.
then return it to motherboard. check your connection with the motherboard power switch.
good luck
Feb 14, 2009 | Jetway (939AGP-OC) Motherboard
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
PixmaiP6700D:error#300. "The printer does not respond. Make sure that the printer is plugged in, powered on, and properly connected to your computer." I've checked all of the connections and...
Error Code300--
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 05, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Menu not working.........
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Panasonic TC-26LX60 26 in. LCD Television
My Computer starts then turns off...
hi buddy!
be sure that the power suppy can can handle all the components thier plug. and check the power button if there is no short circuit ok. also try the other power suppy if you encounter the same problem just reply i am willing to help you ok.
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Jun 23, 2008 | Antec TruePower 550 (true550) 550-Watt...
ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN, Logo
103 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
