Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
Water held in bottom of washer, is this normal?
We've just bought a house with what appears to be with this dishwasher, I have no manual and don't understand why water would be held in the base of the washer. Can you help pls? Only used it a few times so far and just noticed the last two uses. Could it have something to do with different cycles.
Samantha.
    Brigadier General:
  • 3,006 Answers
Hi Samantha. Unfortunately in every house purchase which I've had dealings with where free-standing appliances have been "generously" left behind, they're usually faulty or non-functional.
In your case, the problem is compounded by the fact that it's an LG LD-12BS6. LG make some good products, but dishwashers aren't their strength. Your model is very poorly designed with a number of functional design flaws which LG refused to acknowledge during the (short) production run. They're difficult to get spares for and spares are very over-priced. Worst of all, even when brand new and working, it was one of the worst-performing dishwashers that I've ever had dealings with and simply didn't clean very well regardless of which brand of dishwasher powder/tablet I tried (I used to sell/rent/repair tv's and household appliances). Customer service from LG's domestic appliance division (in the UK) was also pretty awful on the numerous times I tried using it.
In short, even if your appliance is fixable I'd strongly suggest that you don't bother. Bosch dishwashers are excellent and can be bought fairly cheaply if you don't mind used ones but buy the newest ones you can afford. Faults can be expensive to fix, but the parts are readily available for most models over the last seven years and they simply don't go wrong that often.
Regarding your current unit, you've just moved so money is tight and you'll want to avoid buying another for the time being if possible, so check that the drain which the water outlet fits into is not blocked and that the outlet hose is not kinked or blocked. Then check the drain at the bottom of the machine and clean the filters and remove any debris which you encounter. It seems that your machine works but just has a puddle at the bottom so after checking what I've mentioned, run the machine hot and empty with a dishwasher cleaning tablet/bottle/powder inside: it may take a couple of goes if the machine is very clogged, but the idea is that the caustic soda in the cleaner will remove any greasy fat blockages in the inaccessible parts of the drain mechanism.
If this doesn't work, then all you've lost is the cost of the dishwasher cleaner: anything else requires an investment of parts and labour which your machine simply doesn't justify. It's not just my experience of your machine which has been bad, click here. You can also download a free user guide if you click here.
Good luck and I hope that even if I haven't provided a fix I've managed to help you waste money on a lost cause. Please take a moment to rate my answer or add comments if there's anything else about your machine which you'd like to ask.
Posted on Apr 29, 2010
  • Obertelli
    Obertelli Apr 29, 2010
    Sorry, forgot to mention something else: make sure that the machine is perfectly level: the feet are adjustable. The user manual link which I've provided shows you how to do this.
Model w10311121b no power
Hi Scott. It appears you have the same dishwasher as mine bought in 2010- it worked sporadically for several years. I bought one year warranty ($289) in Feb2014 . Over 2 months, service technicians replaced 3 parts (user control board, motor control board and water sensor) hoping that each would fix it. They told me to run hot water before starting a wash cycle. Dish washing cycle failures were still sporadic and it finally lost all power in May2014. Service techs would not come out so I confirmed house power supply with a multimeter and then took the door apart to access the latch. I determined the latch kill circuit was not assembled properly and it had carbon buildup which I scraped off.
If your warranty has ended and you attempt this, do not use a power screw driver with these Torx screws as you can easily strip the threads or damage the plastic user control housing by screwing in too far on the top screws. (especially if you forget to reinstall the internal handle which acts as a spacer).
To disassemble: Remove the top 4 screws and top side screws, loosen the middle and lower side screws as needed. Separate the washer door face wide enough to remove the user control board, let it hang by the cord. The handle will be loose in the way, remove it. The latch has a white plastic kill circuit which is held to the latch with tabs. Unplug the circuit and carefully remove it. The circuit comprises 2 flat metal sheets that are pushed together by the latch lever when the door is shut. These plates separate when the door is open to kill washer power. The latch lever should be under both circuit plates with the shorter plate on the bottom. (long plate, short plate, lever, white housing). Reassemble, remember to include the handle My dishwasher operates properly now.
Apr 19, 2014 | KitchenAid Dishwashers
My Danby 1805 portable dishwasher leaks from underneath only when the water is being pumped back from the washer to the sink. My repair technician was not able to find the leak by looking from underneath...
Your pump may be cracked or a drain hose may have a hole. Also check the dishwasher housing not the cabinet that you can see I have seen small holds due to defects in the plastic that the housing is made up of. Of time with heat and moisture these hols may appear. Look for small crackes in crevices. They are hard to detect once the cabinet is removed start the dishwasher and have flashlight to see exactly where water is coming from.
If you have anymore questions please comment me back.
Jul 28, 2011 | Dishwashers
A couple of times I've found that the dishwasher tablet I'm using (Finish) hasn't dissolved correctly. I found it in the cutlery box the last time. I've been putting it on the 65 degree...
I am guessing you are using the Centigrade temperature scale ... which would be 149 degrees F. 149 is way hot in terms of regular house hold use. Probably just right for a dish washer.
I would expect most tablet detergent would disolve properly at this temperature and with proper water pressure in the machine. You should have plenty of both in this machine. May I suggest you give liquid dish washer detergent a try to see the results?
Jun 01, 2011 | Dishwashers
Fisher paykel dishwasher dd601I runs complete normal cycle and finishes normally. 2-3 sec. after completion the washer motor srarts to run and the f1 fault (flood sw. activated) is dislayed. When the power...
Hi
F1 code indicates an overfill condition which may cause when dishwasher can’t pump out dirty water due to a plugged drain hose.
open dishwasher fully ,dry up as much water as possible then put a hair dryer on hot and direct into the back of the cabinet you will see a grey plastic cover on the bottom floor this is the sensor run on full for about 5 - 10 minutes making sure the heat go into that area. Also don’t overheat your hair dryer, when finished close the dishwasher shut and start your normal cycle.
Thanks for contacting fixya.com
Jan 20, 2010 | Dishwashers
There is a pool of water in the bottom of the dishwasher...just bought the house, no idea what the problem is....draining issues?
the filter in the bottom of washer iss full of crud.. it pulls out so you can clean it.. do this and get a bottle of dishwasher cleaner and run your washer on a hot cycle with just the cleaner in and it should be fine afterwards
Dec 14, 2009 | GE Dishwashers
My AEG 18 in. Favorit 54750Vi has stopped working. It sounds as though it's going to start normally then starts to beep. When I open it the 'Rinse and hold', 'Normal 65*',and 'Intensive 70' indicator...
If for any reason (water leak)the anti flood device at the bottom of the washer is triggered it automatically stops the inlet of water via inlet solinoid and puts the washer in pump out mode. Check the float (polystireene plate with micro switch at the bottom of the washer). Dry any water and determine the reason for water and this should let water in again.
Oct 12, 2009 | AEG 18 in. Favorit 54750Vi Slim-Line...
Dishwasher is leaking water. Water is puddling
There is a tube on the side of your dishwasher for over flow. It sounds to me like your washer was moved and it banged against that line. You can put some caulking around where it enters the washer and that should be fine. The bottom can be several things. If your washer was removed and reinstalled like say maybe floor installation the supply line, or waste line may not be tight. If your unit has not been moved recently it is most likely the motor housing. Take off the one or two covers on the front bottom of the washer. Place the washer through the cycles and with a flashlight see at what cycle and where the water is coming from. It it appears to be coming from the white housing it's the motor. It's cheaper to just replace the unit as these motor housings are around $150.00. Check out craigslist. Hope this helps.
JimmyC
Sep 25, 2009 | GE Dishwashers
We just bought our house and the dishwasher leaked when we used i
check around the bottom of the seal on the door . It might have a build up of old soap and food this will cause a leakIf you clean it good it should take care of it.
Jul 31, 2009 | Kenmore Dishwashers
Water wont stop going in
You stated that your house is new. I see this frequently and what has likely happened is the installer used pipe dope to seal the elbow that screws into the bottom of the dishwasher water valve. They should have used Teflon thread tape instead as the pipe dope will get into the diaphram in the water valve, clog the tiny holes in it and ruin the water valve. The valve on the dishwasher will need to replaced. Hopefully the company that takes care of the warranty doesn't charge you for it. They should back-charge the installer.
Jan 01, 2009 | Dishwashers
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
361 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
