If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
I feel that the problem you are having is because the firmware that is currently on the device is corrupted...i would recommend you to go to the sandisk website to get the latest firmware upgrafe for your device..the link for the firmware upgrade is below..I hope that helps...if you have any more problems please contact me.... http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Several people have said that it didn't work for them but it has worked 100% for me. I've bought about 10 problem Sansas from Ebay and fixed them all at (least 6) with this problem.
You have an error in the firmware. This is damage than is irreparable by any user of a mp3 player. Call the company, tell then that your firmware was corrupted and ask how you can "hard boot" back into a "Fresh copy" of your firmware.
Problem solved! hope this helps!
This may not work for everyone - but try inserting a TransFlash (also called Micro SD)card in the microSD slot, and power on. It may then correctly refresh its database. It worked in my case, with firmware ver11.
http://mp3support.sandisk.com/sansa/Appl...
