Question about Microsoft Windows XP Home Edition
My comp is shoing mi that insert correct dvd-rom
My dell 170L with IDE h/drive & cd rom wont recognise a sata dvd rom ( connected to sata port & power)
Check that jumper settings are done correctly, also check how devices are shown in BIOS.
Sep 14, 2012 | Dell Dimension XPS 400 PC Desktop
Please insert the correct DVD-ROM, select OK and restart application
please help me the game NFS carbon is not working and it is telling that please insert a correct DVD-ROM ,select ok and restart application again
Jul 12, 2012 | EA - Electronic Arts Need For Speed:...
PLEASE INSERT THE CORRECT DVD-ROM,SELECT OK AND RESTART APPLICATION PLZ TELL ME WAT CAN I RAN CALL OFF DUTY GAME FACING THIS EARE MSG
when i enter spider-man 3 game it is saying error please insert the correct dvd-rom select ok and restart application
Oct 09, 2010 | Activision Call of Duty for N-Gage
My desk top comp dosent reconise dvd rw drive
1/ first re install dvd softwere to check
2/ change data cable and power to check
3/ look on biob rom is shoing or not.
4 if not work change another new.
Nov 04, 2009 | Computers & Internet
I purchased a CD-Rom advertised on Amazon as compatible with Asuseeepc and I wanted it for use with the DVD support disc. It works fine with cds but does not recognize dvds when inserted. I have been
A CD-Rom will only recognize CD's. It must be a DVD-ROM to recognize DVD's. DVD-ROM will recognize CD's ,but not the other way around. No drivers needed for thes, they are plug and play.
Char S.
May 20, 2009 | Teac PortaCD 224PE External 24x CD-ROM...
My emachines dvd rom is not detecting a dvd in the drive
Dissamble the dvd rom from pc. Open it and clean the laser with a soft cloth or try a dvd lens cleaner disk. You can buy it from any hardware shop. Connect the cables correctly. Start with a fresh dvd disk. If your pc still can't detect dvd disc, replace dvd rom with a new one.
Feb 23, 2009 | eMachines T5274 Desktop PC
Hard drive and dvd rom stopped working after changing to cd-rw, the ide cables have to unplugged to get any response from hard drive or dvd rom
Have you done the proper connection ? Please check out the Power & Data cable inserted firmly in Hard Disk, and DVD rom, after then check out the jumper is inserted correctly.
Unplug the Ram for 5 minutes and then try to start PC. Hope this works. Let me know the status after then.
Oct 09, 2008 | Apple Computers & Internet
DVD-Rom's problem! Plz help!
* please check dvd rom cable(ide cable) is connected properly
* check powerconnecter is connected tight
jumper settings:
* set ur hdd as master
* dvd rom as slave in ide1
* set master to dvd writer in ide 2
Jun 19, 2008 | Computers & Internet
Why display "disk full" or "Wrong disk" and the disk is new
Try to used Nero, application that will help your driver execute the appropriate task to execute.
Please rate me SOLVED
Nov 19, 2007 | Teac (CDW552GA02) (CDW552GA02/10PK)...
Dvd rom
not necessrilly some dvd rom drives play only dvds an cds but don't burn them. it may burn cds but there is a 90% chance your drive can't burn dvd's
Nov 17, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Microsoft Windows XP Home Edition Logo
16 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
