Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Check water light comes on but filter cleaning doesn't help
When I turn on the dishwater, there is a humming sound and after a few seconds the check water light comes on. I have tried cleaning the filter, checked the tap and all seems to be well. But it just doesn't come on.
  • Alex
    Alex Apr 26, 2014
    I got the same problem. The symptom is similar. After beep a while, it then start working. This pattern repeat, and sometime work, sometime does not work. Bosch sucks!
No sound
Posted on Apr 29, 2010
What doesn't my dishwater finish its cycle?
What is the make and model number
Jun 09, 2013 | Dishwashers
When you start it the engine just runs and the machine doesn't fill up with water
Just beyond your filter that you cleaned you will feel some blades, plastic. These blades should turn freely, these are the pump blades, something shd be blocking it, which over flowed from your dirty filter.
Another thing is did your washer not fill with water on starting it? Well take of the power plug from the wall (imprtant before all these jobs!) turn off the washer, turn off the wall valve, unscrew the pipes to see if water flow is gud, check to see if anything is blocking your filters and he washing machine inlet valve. It has a fine filter and is detachable to clean.
Helped?
Mar 10, 2013 | Washing Machines
Hyundai accent 2001 will not start all lights work radio works heater fan works battery in 3 months old when I turn the key all i hear is a humming sound for about 1 min. than nothing. weather has be
The humming would be the fuel pump coming on. It should only hum for a few seconds, then shut off.
Your problem is with the start circuit from the battery to the starter, or from the ignition switch to the starter solenoid. Check the connections at the starter (the big cable) for tightness.
Is the battery charged up enough to turn the engine over? Check by turning headlights on and observe while someone turns key to crank. If they dim a LOT, then either battery is too low, or the starter is bad and needs removing for testing. If brightness doesn't change, then the circuit from ignition switch to starter solenoid is likely not working. Check for 12 volts at the small wire to starter solenoid with key in cranking position. If you have power there, the solenoid may be bad. Remove starter for testing. If no power at solenoid in starting position, then either the ignition switch is bad or the neutral safety switch might be the problem, or the wiring from the switch to the starter solenoid is not passing current.
Good luck.
Jan 14, 2012 | Hyundai Accent Cars & Trucks
After the wash cycle the unit will not empty, according to the feedback on this page they sujest a dishwater cleaner, can you tell me what type and where to obtain it.
I don't know that a dishwater cleaner will solve your problem. More than likely the pump is no onger functioning which is located on the bottom of the unit. When the dishwasher goes into the discharge cycle does it make a humming sound or does it do nothing. All pumps make sound when discharging the water from the basin. If there is no sound present then the pump is not functioning........if the pump is making a humming sound then it is locked up. Let me know please thanks.
Deathstalker
Sep 01, 2009 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Lights flashing water wont drain but making a humming noise
hello sir,
Please do the following checks
  1. nspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Click on the highlighted words for details on how to check.
Jun 04, 2009 | Maytag MAH2400A Front Load Washer
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
Problem with Miel dishwasher: no water
if the valve is humming and the tap is on it should fill.is there a plv fitted to the tap somtimes they fail.i had one today on an asko for not filling.remove the hose from the dishwasher and turn the hose on into a bucket to see if water comes through.the valve could still be faulty.hope this helps.
Mar 19, 2008 | Dishwashers
What does F7 Means?
The F7 means that the drain filter is blocked or your water pressure is low. Check and clean filters. Good luck !
Apr 25, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
622 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
