Question about Samsung SyncMaster 731B 17" LCD Monitor
On every start up, my Samsung screen "sync master 731 bf" needs 10 -15 attempts to show the desktop. It trays several times but the picture lasts only for 1-2 seconds and the screen is turning black again.After several switching's beetwen analogue and digital connecting options, finally the screen is working properly . Please ,have you any solution for this problem ?
  • Samsung Master
  • 1,684 Answers
The slow startup is an indication that your power supply board i failing. The board tries to power up but the voltages are not stable so it shuts down and retries over and over until they do level out and you get a picture. This will get worse until it dies all the way and you get no power at all. The repair involves replaceing a few parts on the board. If you can solder then you should be able to do the repair yourself. We have an article posted here that shows what needs to be done: http://www.ccl-la.com/blog/index.php/service-request-form/ The 731 uses the same power supply board as the 720. If you don't want to do the repair yourself we do offer a repair service, here is more information on that: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Apr 29, 2010
2 Suggested Answers
  • 1684 Answers
SOURCE: Start up problem with Samsung Sync Master 731BF 17" monitor
Your internal power supply is failing. There are parts called capacitors that are not functioning correctly and this causes the power supply to not be able too stabilize the voltages that run the monitor. After repeated power cycles the capacitors will hold enough charge to function until you urn the unit off and then they discharge so you have to start all over again. We have a step by step repair guide article posted at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ This should get you back going again. If you don't want to do the repair yourself we do offer a repair service, you can get that information here: http://www.ccl-la.com/blog/index.php/service-request-form/
Buddy
Corporate Computer
www.ccl-la.com
Dual samsung sync master s27a350h monitors
Hmm. Maybe your graphics card or RAM can't cope with both? Try showing usage on Windows Task Manager (CTRL+ALT then DEL)
Feb 23, 2014 | Samsung LCD Monitors S27A350H SyncMaster -...
Samsung 920nm sync master Black screen
Samsung sync master monitors were well known for bad capacitors, if you have a esr capacitor meter you can check in circuit, if not look for dome shape at the top of the capacitor, a dead give away it is open, also check for poor solder connections in the power supply inverter board area.
Jun 20, 2012 | Samsung Computers & Internet
I have a Samsung Sync Master 731BF and when I switch it on, the power light stays on but the image is black and wont show any picture whatsoever.
Hook a spare monitor to the computer to rule out the Video Graphics Card in the computer, if okay! It is the Samsung, "power supply issues" bad capacitors, sometimes show a bulge at top. But to be on the safe side replace the video cord from the computer to the monitor if possible.
Mar 31, 2012 | Samsung 731BF (Black) Monitor
The DVD tray only opens after I push the button 3 or four times. When I press the button, the tray attempts to open but seems to be blocked. Finally, after several attempts, the tray will function...
The optical unit - it's tray mechanism to be more precise - has aged and it's starting to seize. Unfixable, you will have to replace it. Luckily a new dvd unit costs less than $30 and can be bought even at Walmart. Installing it is a 10 minute job that you can do yourself easily.
Dec 28, 2010 | Dell Dimension 2400 PC Desktop
Buddy
Corporate Computer
www.ccl-la.com
Apr 29, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
Dec 08, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Blackberry Curve 8330 Pasword Lockout
Try removing the password before attempting to sync to your computer.
On the pressing the keys and getting only numbers sounds like the numbers shift is locked.
simply press the alt on the bottom left of your keyboard.
the use of numbers only or sometimes caps only will be indicated on your screen. observe the symbols along the top and the bottom .
type something as if you were going to send a text message to text that the keyboard is set to normal and lower caps.
Oct 10, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
My 50SBX70B flicks than lost the power
Symptom: NO HOR SYNC
Cause: DEFECTIVE I008
Symptom: No Horizontal Sync. When PinP is called up, main picture may lock up for a 8 moment, then it goes back out of sync.
Cause: I008 defective (Sync Switch)
Jan 15, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Samsung SyncMaster 731B 17" LCD Monitor Logo
646 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
