Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
I have a Kingavon 1 million cp spotlight (model SL1000EB ) I also have a lot of unidentified chargers. Does anyone know what charger fits the spotlight?
  • 843 Answers
I will assume that your light has rechargable NiCad batteries. Use the following advice ONLY if you are sure this is true. If the light is more than a couple of years old, this is probably true. Of the plug has to fit, but it must also have the correct Polarity, Voltage, and Amperage. The spotlight should be labeled where you plug the charger into it with these three critical parameters. They will also be indicated on the chargers. POLARITY --- If it takes a round plug, the polarity is indicated by a symbol that looks like a C, usually with a plus sign inside of it (this indicates that the center contact is positive). VOLTAGE --- this will be expressed as VDC input on the light, and VDC output on the charger. The voltages only need to match within about 10%. AMPERAGE ---- this will be expressed as mA (milliamps, which is thousandths of amps) or as A (which is Amps). 1000 mA = 1 A. This doesn't need to match precisely either. But if it's too low, the charge will take a while and you might burn up the charger (possibly literally burning it). If the amperage on the charger is high, that's OK, so long as the voltage is not high as well.
I hope this helps, Thanks for using FixYa. Al Kupchella
Posted on Apr 29, 2010
I dont have anymore information to give What I gave should be enough. I just need a charger for that vector sport spot 1,000,000 series its yellow with black ring around prism
To recharge the battery, you will need a 12VDC 300mA adapter. It will take 12 to 15 Hours to charge.
Try Radio Shack, and take the light with you to make sure the charger fits the hole.
Jul 27, 2012 | Vector 1 Million Rechargeable Spotlight
Lost my charger for my vector sport spot 1,000,000 power series
My spot light just crapped out, dead battery.
I have a wall chargerand car charger available along with the on/off switch and bulb. contact me dspiper@comcast.net
Jul 25, 2012 | Vector 1 Million Rechargeable Spotlight
Lost charger for my vector sport spot 1,000,000 power series , where can I get another one?
Take your light to Radio Shack, and make sure the barrel fits.
Charger for 1 million rechargeable
Take the light to Radio Shack so you can make sure the barrel fits. To recharge the battery, you will need a 12VDC 300mA adapter. It will take 12 to 15 Hours to charge.
Jun 20, 2012 | Vector 1 Million Rechargeable Spotlight
WHAT IS THE VOLTAGE OF MY VECTOR MODEL VEC117FS
6 volts rechargeable battery. Check with the manufacture for a recharger for the 110v and or a car charger for your light.
Mar 27, 2012 | Vector 1 Million Rechargeable Spotlight
I have a victorlite 1.5 million candle power spotlight lost charger but I have a 12 volt 1000ma- will that work??
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Jul 13, 2011 | Vector 1 Million Rechargeable Spotlight
Looking for a 120V to 12V charger for a Professional"s Favorite 17.5 million cp spotlight.
You should be able to use any AC adaptor that puts out a 12 volt DC current and has correct polarity. Based on the estimated size of the battery powering your spotlight, you probably will want a charger that provides at least 1000 mA of power--the charger that came with my ThorX 10 million cp spotlight puts out 1500 mA to charge the two batteries in that light. A lower amperage rating will increase the amount of time it takes to charge your light, but it should still work.
You can find a replacement charger at Radio Shack, which sells chargers that can be fitted with a variety of different tips. However, you might be able to find a cheaper universal charger with a tip that works at a discount store like a Walmart, or you might get lucky at a thrift shop or second-hand store and find a 12v charger that will work with your light. 12 volts is a common output for a lot of different devices, so it shouldn't be hard to track a replacement down. Just make sure you have the adaptor tip polarity correct, or else you could make your battery explode if you try to charge it with reversed poles.
May 25, 2011 | Camping, Backpacking & Hiking
I have vectorlite 1.5 Million Candlepower light I want to know the ac charging adapter specification. We kind of lost track of particular adapter in recent moving :(. we appreciate your help....
Most of the Vector spotlights use a class 2 charger with an output of 12VDC 400ma with a positive (+) center connector, which are very common. I have several of these chargers from different manufacturers, and I use them interchangably on whichever spotlight I happen to plug them into.
One complication with my Vectors is they use a coaxial connector plug on the spotlight end that is a size N, which is being phased out and Radio Shack doesn'd even carry any more. If you hae a box of misc chargers, find a 12VDC one with a connector that fits your 1.5MCP light, and that is probably the one that came with your light.
Note that you can also charge your light with the cigarette lighter adapter cord that came with it. So if you can't find an AC transformer that fits but you have your cigarette lighter adapter cord, you can buy one of those cigarette lighter size gadgets that plugs into an AC outlet, and then plug your cigarette lighter cord into that.
Jun 28, 2010 | Vector 1 Million Rechargeable Spotlight
New wall Charger needed
Depends upon the model, but most use 12v 500Ma batteries w/ a barrel-pin connector.
You can buy one here, or search this site for your model:
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=69262&tid=16032
Sep 22, 2009 | Vector 1 Million Rechargeable Spotlight
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
246 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
