Question about SmartDisk FireLite 40 GB Hard Drive
Firelite external drive wont read all of new disk
I've had this external drive for a few years and recently upgraded the hard drive with a new 360GB, but only 128GB can be read. I've fished round on the internet and think this has something to do with PATA - which I cant get to grips with. Does this refer to the drive or the wiring in th enclosure, or is it a driver issue?
  • Chris Mayled
    Chris Mayled May 11, 2012
    No one had a solution so I had to bin the enclosure and buy a new one. Suspect the hardware of the ageing drive had a maximum GB limit.
    Genius:
  • 1,274 Answers
I had a 500 gb pata drive which was read just fine, it's possible that it was just the file system on the drive. if you still have it plug it back in go to disk mgmt and try to format the entire drive with fat32 or exfat, or even ntfs.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Posted on May 12, 2012
3 Suggested Answers
SOURCE: SmartDisk FireLite XPress 120 GB USB External Hard
Hola!!!
I have this external drive and the truth is that it is very good. But I have a s e doubt that the digital display does not turn me, and I do not know if it is broken or is it because only you connect the USB cable and did not put the current transformer 5Volts. I need someone to help me and tell me what has to be repudiation. Thank you very much!
My Email: @ gmail.com rodolfo.gomez1990
Posted on Jun 04, 2010
lock123
  • 6831 Answers
SOURCE: (Smartdisk)firelite 40G external hard drive wont work with vista
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Iomega hard drive won't let me view files on my TV
I have suggestion for you please scan your external hard disk with a good antivirus and then anti malware bytes. Possible your problem will be solved. Thank you so much....
May 06, 2012 | Iomega Select 1TB USB 20 Black External...
My firelite use to show up as firelite, now it showing up as the d drive and wont open. Its also asking me to format it in order to open, what should i do?
Junk it - the controller inside it has failed and the pc no longer recognizes it as a external disk and that is unfixable.
Aug 22, 2011 | SmartDisk FireLite 80 GB Hard Drive
My computer will not recognize my external hard drive what do i do?
There are a few possible causes for that. Here is an article on troubleshooting external hard disk problems:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Hope it helps!
May 25, 2010 | SmartDisk FireLite 40 GB Hard Drive
Smartdisk Firelite 120 GB wont delete
Try to reformat the external hd thru the disk utility.
Sep 03, 2009 | SmartDisk FireLite USBFLB120 120 GB USB...
Firelite USBFLB 160 won't mount
Problem is just external...First try in another pc,if it still wont work so just buy new external and put that hdd in new external...
Feb 16, 2008 | FireLite (USBFLB80) Hard Drive
Firelite Hard drive read as "local disk"
1)Run CHKDSK ON that disc
2)Run antivirus to scan disc
Dec 27, 2007 | FireLite (USBFLB80) Hard Drive
My mac computer do not reades or recognize my external hard drive 60GB smartdisk from firelite
well. Open Disk Utility in the Applications folder under Utilities and see if it shows up and possibly mount it from there. Also open the System Profilier (also in the utilities folder) and check under USB - if that's how it's connected.
Nov 12, 2007 | FireLite (USBFLB80) Hard Drive
FireLite FWFL40 - need to upgrade the HD
Hi, Your basically correct, the only requirement is to physically fit the enclosure (2.5inch), other than that, hard disk capacity is a matter of your personal preference/need; Toshiba is one of the better brands. Others are Seagate, Maxtor to name a few. I guess it's a matter of who can provide better after sales support. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | FireLite (USBFLB80) Hard Drive
Smartdisk firelite
please use a recovery program for mac and then once all files are recovered then repartion hdd in disk utility then copy back all files to hard drive or change your external drive as you are the fourth person to have this problem with firelite hard drive for the mac sounds like a compatabilly issue with mac os systems
Jun 01, 2007 | SmartDisk FireLite 40 GB Hard Drive
SmartDisk FireLite 40 GB Hard Drive Logo
59 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
