Question about Lexmark X1240 All-In-One InkJet Printer
Lexmark x1240 Feeding incorrectly/crooked
My lexmark x1240 Scans fine but it can't Print paper.
Whenever it starts to feed for a split second its moving in straight but then it goes in crooked and kinda jams, I am not sure if the rollers need to be cleaned or what but i would like a few suggestions.
and if it is the rollers how to i get to them to clean them/replace them if necessary.
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 29, 2010
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Whenever I try to print something I keep getting
It's a possible hardware issue in the feeding mechanism. Try to remove the cartridges from the printer then close the cover. Remove the sheets of paper. Unplug the printer from the power source. Wait at least 30 seconds before plugging back the printer to the power source. When the printer's ready, reload the cartridges. Load some paper but don't overload as this may send wrong information to the printer. Have the paper guides lightly touch the sides of the paper, thus avoiding shifting of paper when it feeds. Let it print an alignment page and do some test prints from computer. If problem persists, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 25, 2010 | Lexmark X4270 All-In-One InkJet Printer
My Lexmark x1240 won't print anything. I click on the print icon for whatever it is that I'm trying to print. Instead of getting the ''Printing Started'' confirmation, Windows (Vista) prompts me to save...
uninstall the printer and reinstall it if it says it is printing to your printer. under printers your printer should be set as default. test by selecting print from the menu. it should come up to a screen showing you which printer you are printing to.
Mar 20, 2017 | Lexmark X1240 All-In-One InkJet Printer
Paper misfeeds, more on one side then the other
hi
this mostly occurs due to either major dust accumilaton or paper peices being stuck to the paper feed rolls
try and clean the rolls with some spirit and this should start working fine again
hope this helped
cheers
Jun 23, 2009 | Lexmark X1240 All-In-One InkJet Printer
When trying to print paper pulls to the right and jams
try feeding the paper first, mine pulls to the right also, but if I hold it when is jerks, sometimes it will not jam
Dec 02, 2008 | Lexmark X1240 All-In-One InkJet Printer
Paper not feeding on the left hand side of our lexmark 5100
open the backdoor and try to move the rollers in upward direction...if the roller on the left is hard to move then..replace the machine.
Nov 25, 2008 | Office Equipment & Supplies
I have a lexmark E120, great little printer just went to print and it was down to one sheet of paper, I got a batch of papers to feed in, as I was printing a large doc, and in a split second it started...
In the back of printer you have door. Open it and there you can clear jam. Remove paper but slowly and easy. Close door and it will work fine.
Good luck.
Sep 15, 2008 | Lexmark Office Equipment & Supplies
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark X1240 All-In-One InkJet Printer Logo
212 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
