Question about Kenwood KRF-V4060D Receiver
Need a new remote control KRF-V4060D - Kenwood KRF-V4060D Receiver
  • 8,197 Answers
You can order a replacement remote on the link below.
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=KRF-V4060D+&uuid=12725540403730
Good Luck and please rate 4 thumbs up.for the free answer.
Posted on Apr 29, 2010
Kenwood krf v5030
2290,2294,2295. Try these codes. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 16, 2014 | Televison & Video
Kenwood krf v5300d
I'd Google "Kenwood KRF V5300D remote control". Surely you will find a replacement available from someone. This worked for me to find one for a LG BluRay player.
I found them in the UK for example, at http://www.findremotes.com/remote-controls-1/kenwood-remote-controls-krfv5300d-1238517.htm
Oct 13, 2013 | Audio Players & Recorders
Remote problem for Kenwood KRF V9992D, need new remote
You can almost always find a good replacement at newremotecontrol.com. Avg price is 25 dollars.
Apr 18, 2012 | Kenwood Audio Players & Recorders
Kenwood krf-v4060d receiver display problem, its work for some time but after that no display, sound work fine but not able to see any display on receiver
it is possible that the voltage to the filament of the display is absent. This is normally a 3.6 volt AC which comes from the transformer and it can be lost a the connectors or the circuit board. It will be best to use a multimeter to trace the voltage to the display unit. check the voltage to the display driver IC, check the negative grid voltage to the display , if there is an open resisitor of the feed to the display voltage to the IC. Finally check the continuity of the filament of the display unit.
The driver IC is also a suspect , sumulate heat and see if the fault comes up easily which can confirm the case.
Sep 05, 2011 | Kenwood KRF-V4060D Receiver
Hi, I have a KRF-4060D receiver and my problem is, that however the receiver is set to auto detecting, when I start a dts movie, the receiver does not recognize it as a a dts signal. could you please...
What DOES it detect instead - analog or Dolby Digital? If the former, the digital bitstream is not being seen at all - check the digital audio-bearing cabling.
If the latter ---
As dangerously loud undecoded digital bitstream [hash] "noise will be produced when a DTS source is played by selecting the analog input", the DTS soundtrack is not necessarily the default for a movie soundtrack and may need to be manually selected under the movie's own Audio Setup menus.
Jul 11, 2011 | Kenwood KRF-V4060D Receiver
The spindle connecting the volume control knob to the control itself has broken. Does the whole assembly need to be replaced? I don't have the old spindle.
Do you mean the spindle on the back of the round knob? If this is the case then you simply need a new knob from the manufacures as the bit that fits over the pin coming out of the machine is a one peice moulded item. If you are very nice to customer services at Kenwood, they may send you one for free. Next time be a wee bit more careful not to knock the control knob as it is quite delicate.
IF on the other hand it is the volume spindle couming out of the unit, then yes this is a whole item replacement. This will need to be repaired by either a accredited Kenwood repair agent or a competent repair shop depending on whether this item is still under gaurantee or not.
Mar 15, 2011 | Kenwood KRF-V4060D Receiver
My kenwood krf-v4060d reciever on/off switch is faulty, it stays switched on for a few seconds and then switchs its self off.can i get a replacement ? i have had not much luck here,any suggestions !
The problem is not likely to be the switch itself. The unit is rpobably going into "protect" mode because of a problem internally. Try removing all the cables and try to turn on the unit. If the behavior remains the same, the output section requires repair. The most common failure is the output transistors. Expect a parts cost in the $40-$60 range.
Dan
Dec 09, 2009 | Kenwood Audio Players & Recorders
Kenwood KRF-V4060D Receiver Logo
216 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
