Question about Fisher and Paykel Fisher & Paykel Washer
F&P washing machine:GW709 doesn't cut out when filling
Fisher & Paykel Washing Machine GW709 doesn't cut out when filling - is this a simple sensor problem fixed by cleaning out a tube, or will the whole control board need replacing by a service technician who will charge $120+ just to come and look???
  • Fisher and P... Master
  • 713 Answers
Could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Posted on May 04, 2010
Fisher and paykel GW709 error codes 01001111
those numbers suggest code 79, which is not a fault code. but by the sounds of it, you just have blocked pump. turn off and lean back machine, unscrew pump (front right) and clear blockage. you may want to empyt water before unscrewing pump.
Jul 18, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel smart drive excellence GW709 no power!
The wires have stretched some wires have broken.
Those wires can be put back in the plug,
Get a paper clip and push the pin out from the back of the plug
remove broken insulation left in the plug cut wire clean insert into plug and tap the pin down with small flat blade screwdriver.
Apr 18, 2013 | Fisher and Paykel Washing Machines
I have a Fisher & Paykel GW609AU washing machine
keep it simple, make sure water is on to both hot and cold hoses. Trip switches for door (and sometimes soap draws) can prevent machine working. Try asking a few logical questions. Has the machine been moved recently? If its out of level this could be a problem. Check solenoids are working (these are electrical taps at the back of machine which hoses hock up to), to do this try both hot and cold settings. Even try changing water level settings to further attempt to deduct were problem might lie. hope this helps and let us know how u go
Aug 08, 2011 | Fisher and Paykel Washing Machines
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Turn it on and it won't fill up altho it tries...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 19, 2010 | Fisher and Paykel Fisher & Paykel Washer
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing machine slow to fill
yes or a water pressure issue, mosty when using hot or warm
May 19, 2010 | Fisher and Paykel Active Smart E522B...
Washing machine (F&P) model no: 12502 will
likely fault is electroic motor control board,in some models eg: gw709 if the pump is open circut the motor controlwont light up check this too
May 15, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel smartdrive 508 filling slowly
remove the hoses and check for any kind of clogging or restriction in the line there may also be a problem with your fill valves
Mar 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
355 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
