Question about Vector 2M Pwr Rch Spotlight
Main light no longer working'but smaller ligh is?
  • 973 Answers
Battery is dead, you can order a new one from www.dewaltservicenet.com
Posted on May 25, 2010
  • Boneebone May 25, 2010
    You can also locate a Black and Decker Service Center close to you and pick one up so you can save some money on shipping.
LOOSING COMPRESSION WHILE DRIVING WHAT IS WRONG
Its possible the main problem is the short drives you do. This is not enough for the engine to reach running temp long enough to keep the smog valves etc clean. You cannot loose compression while driving so go for a long high speed drive and watch in the mirror when you hit the throttle for lots of black smoke. If not get the smog system checked / cleaned at a garage and either change your car to a smaller engined type or do longer runs once a week.
Aug 12, 2015 | Cars & Trucks
Tip
Ge profile oven probe and bake lighs flash intermittently
<P> </P> <P>unscrewed probe housing, insured  black/white wires were secured to connectors and re-installed housing.  ( white wire was not  fully seated into connector Lights no longer flash.<BR></P>,
on Aug 20, 2013 | GE Ovens
What make all the lights go out on 1987 nissan zx
My guess would be one of the main fuses for the headlight switch, or the headlight switch itself.
Aug 23, 2012 | 1987 Nissan 300ZX
Low oil pressure 2001 chevy express.
Probably the crank shaft needs regrinding and oversized bearings fitted.
Aug 12, 2017 | Chevrolet Express Cars & Trucks
Hello, I have both of the amber and green ligh
Kind of difficult to suggest anything. What amber & green lights? Are you talking about the LED status lights?
May 21, 2010 | Dell Dimension 2400 PC Desktop
2M Pwr Rch Spotlight: main light no longer working'but smaller ligh is?...
The rechargeable battery is dead, it has just enough juice to light the LED light, but not the main one. I have two identical Vector lights VEC119CO, one with the same problem you are describing and the other one in perfect working order. I tested it by hooking up the leads of the non-working light to the battery of the working light and the main light turned on.You can order a new battery or any parts you need for a Vector product from Black and Decker, either online or if you live close to a Service Center you will save money on shipping by picking it up.
May 18, 2010 | Vector 2M Pwr Rch Spotlight
Hotpoint wt 540 mini light and on off lighs flash changed mogel board switched on and all lights now flash hotpoint w
f01 was the origional fault motor triac failure-when replacing module was it prorammed correctly-clarify on what lights are now flashing-if everthing is flashing like a bad connection then the main board is a faulty one
Nov 09, 2009 | Washing Machines
Switch on xbox withing 5 seconds a red ligh appears bottom right but if you turn the xbox on ots side the red light slips to the bottom right no sinal to television
This is the video chipset failing, couse: heat problem, the main board expands by the generated heat then cousing the solderings of the video schipset to brea, get the xbox to a repairs man.
Aug 28, 2009 | Microsoft Xbox 360 Console
Bulb only illuminates when i engage turn signal.
Hi: tail is on its own circuit and utilizes the longer thinner element in tthe bulb --- the brake and turn utilize the short thicker element in the bulb---- two different circuits. If bulb fails on tail ligh then the bulb is more than likely burned out. When you take the bulb out, look at the elements and you should see a broken thin filiment. bulb is bad, replace. good luck
Apr 19, 2009 | 2000 Ford Expedition
Vector 2M Pwr Rch Spotlight Logo
69 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
