Question about Epson Stylus CX5400 All-In-One InkJet Printer
All leds are blinking continously in Epson stylus cx 5500 printe
All the leds are blinking contiously when powering o the printer it is intializing after that leds bliking contiously
    Scholar:
  • 118 Answers
turn on/off, unplug, plug inall leds are blinking continously in Epson stylus  - 2_bing.gif, should reset configs.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Posted on Apr 29, 2010
STR F6654 is not workimg ,power led is bliking what is the cause?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
If STR does not work, how do you get the power light ON at its front panel?
May 22, 2017 | Televison & Video
Samsung TV power output is bliking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Apr 17, 2016 | Samsung Televison & Video
I buy new then i pluged power socket my progector indicat red light i start standby butten the progector return standbay mode and red light bliking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 02, 2015 | Televison & Video
Contiously blinking display canon iR3320i
Since you did not specify what the "blinking display" was, such as an icon or actual code. I suggest you go the Canon Support Web Site at:
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2200_2220i_2220n_2800_3300_3300i_3300e_3300en_3320i_3320n/imagerunner_3320i
Nov 04, 2014 | Canon Office Equipment & Supplies
Error bliking green light an not printing
If only the power green light is blinking, you could try a printer reset that may correct the problem.
1. With the printer on, disconnect the plug from the electrical outlet.
2. Wait at least 3 minutes
3. Plug back into the outlet.
Dec 27, 2013 | HP Deskjet 2050 All-in-One Printer
Power light blinking red
if the lamp goes out after the red led goes on, there is a fan issue and the projector is overheating or the ballast/power supply can't hold the voltage.
Aug 04, 2009 | Sanyo PLC-XU47 LCD Projector
Hp 2460 printer bliking lights
I found that turning the printer off, re-seating the print cartridges resolved this issue for me. Good luck.
Sep 22, 2008 | HP Deskjet 2460 InkJet Printer
HP3550 PROBLEM
I eventually discovered that the blinking was simply caused by the printer running out of ink. I intially dismissed this as a possibility because Windows always used to warn us when the ink was getting low. However, I presume that we no longer get those warnings now that we're running on Vista rather than XP - a compatibility issue I guess.
Aug 12, 2008 | HP DeskJet 3550 InkJet Printer
Printer light contious blinking
first you can chek your scaner assemble.
then chek proper conect cable
May 27, 2008 | HP LaserJet 3055 All-In-One Printer
Epson Stylus CX5400 All-In-One InkJet Printer Logo
175 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
