My Hotpoint Ultima WT960p works in all ways but drum doesnt move!
My Hotpoint Ultima WT960p works fine but the drum does not rotate. I can select any program from the menu, the machine starts, it will fill with water, the timer will count down, the machine then empties itself, but all the way through the cycle the drum remains motionless. The belt has not broke. Any help would be greatly appreciated.
  • 1 more comment
  • sullybear Apr 29, 2010
    Hi, thanks for the reply. Have checked all of that and that is all as it should.
    Thanks
  • sullybear Apr 30, 2010
    hi.
    I van confirm that the motor is not running. The belt is not broke and the pulley is fine. I have turned the drum by hand and it turns freely. Its as if there is no power going to the drum.
    Thanks.
    Hi, Thanks for the reply. I have checked everywhere in the machine but cannot find the sheet that you describe.
    Is there anyway to check the power to the ECU board? Is the ECU the circuit board that is on the front of the machine or is it located somewhere else.
    Thanks in Advance.
    President:
  • 2,468 Answers
Have you retrieved the tech sheet out of the machine and run any of the diagnostic tests on this sheet? its usually under the top cover or on the side,inside the unit, it sounds as if maybe you aren't getting the 3phase motor power off the e.c.u. board to power the motor,this board takes single phase power and converts it to 3 phase power to change the direction of the motor so that it doesn't need a transmission that would do the same
Posted on Apr 29, 2010
    President:
  • 1,554 Answers
Check the motor whether it is running or not while the washer is going through the cycle. The motor might be running but the belt is slipping, the motor pulley is broken, or the drum pulley is broken.
  • 1 more comment
  • Jahn27
    Jahn27 Apr 30, 2010
    In relation to my previous post, are you confirming that the motor is running, the belt is not slipping, the motor and the drum pulleys are not broken? If that is so, how could the motor run without turning the drum and the belt not slipping? Please clarify and provide more information as much as you can.
  • Jahn27
    Jahn27 Apr 30, 2010
    Turn the drum by hand to check if it is turning freely.
  • Jahn27
    Jahn27 Apr 30, 2010
    What you need to check is the power from the electronic control to the drive motor. It seems that the motor is not being powered up either due to a faulty wiring harness connection, a fault motor, or a faulty electronic control. But the electronic control should flash a code if the motor or the connection is at fault. The control is most likely at fault losing its ability to detect that the motor is not running. The electronic control is where all the working components are connected including the circuit on the front.
    The function of the electronic control can be verified by disabling a working component such as the drain pump or the water inlet valve. Shut off the water supply then run the washer; it should flash H2O.
Error code F08 FLASHING WILL NOT SPIN
The pressure switch is stuck and the machine thinks it is full of water. You need to remove the top, look for the pressure switch and unplug the hose on it and blow air through the hose. Then replace the hose on the switch. It looks like this: http://www.yourspares.co.uk/parts/hotpoint/washing-machines/wt960p/parts/ys56011/hotpoint-wt960p-pressure-switch-spares-C00194160.aspx
Feb 06, 2016 | Hotpoint Ultima WT960P Washer Front...
My machine is stuck on rinse hold and child lock
Try unplugging for 5 min and plug back in.
if not working still order new interface stuck button sounds like
someone has been hitting buttons to hard or soapy water spilled on pannel
Mar 08, 2015 | Hotpoint Ultima WT960P Washer Front...
Where is the pressure switch on a wt960 hotpoint washer
usually located in the panel on the left said has a clear plastic tube going into it
Aug 01, 2014 | Hotpoint Ultima WT960P Washer Front...
My Hotpoint Ultima WT960P has developed a very severe vibration under load on fast spin - how can I fix this Tom
hi there....most probable cause is a main bearing failuer..or a cracked spider unit at rear of inner drum.......both scenearios require a comleted strip down of the wash tub
regards Sir Galahad
Aug 16, 2009 | Hotpoint Ariston AW125 Front Load Washer
Drum wont move
Check the motor and the belt on the back of the unit behind the rear plate. Make sure that the belt is attached and the motor is spinning. If this helped please rate. Thank you
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima extra wma64
hiya
check the wires which run from the motor up to the main pcb, it's quite common for these to rub together and break. i have came across this a number of times now.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960p lcd display very dim ...machine works fine otherwise
Assuming that there is no provision for a panel darkening mode...the panel LCD is probably bad. You might try accessing the unit and unplug/replug in each connector. Sometimes, this will help. Be sure the wall plug is removed before doing this.
Mar 31, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
