Question about Alpine Car Audio & Video
I have an ALPINE 8030B car security system but have lost the wiring diagram. I would really like to insall it in my truck but I can''t figure out what wires go where.
  • 50 Answers
SOURCE: need wire diagram to hook up trailer lights, truck not factory equipped w/harness,
I'm assuming you're just going to splice into the tail light wiring so that's what these wire colors are:
at the tail lamp 3 way connector:
black and yellow = park lamp
dark green and brown = left turn signal
there should be another connector with violet and black wire for reverse lights.
the stop lights are turned on through the turn signal circuits.
Posted on Apr 12, 2009
KaeZoo
  • 156 Answers
SOURCE: wiring diagram
Red: voltage source controlled by the ignition key Yellow: constant voltage source Black: ground Blue: power antenna activation wire (if equipped) Blue/white: amplifier activation wire (if equipped)
Posted on Jun 06, 2007
  • 5 Answers
SOURCE: Vibration after spark plug/wire change
Check your firing order
Posted on Aug 17, 2008
i need the color codes wires
Posted on Sep 12, 2008
Benimur
  • 6966 Answers
SOURCE: car stereo wiring diagram
Hi again,
I was made to understand that your particular model is exclusively available only to the European market and not here in my country.
The only info I can provide is links to the Mitsubishi-Forums.com:
  • rear view image of the head units in some version/models. Pls confirm if similar to your MRS587702HB.
Alternately, pls try Oakley Mitsubishi.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 15, 2008
Alpine wiring diagram
If you contact Alpine they will be able to tell you if there is an adapter that will plug right into your existing OEM harness. If not then, you'll have to figure out Which wires are which on your OEM harness, here is the Alpine wire code:
Alpine wiring help
HU harness color code pretty much universal.
red=ignition
yellow=battery +
black=ground
blue/white=remote turn on
blue=power antenna
pink/black=audio interupt in (not sure if you have one)
speaker wires
gray=right front
violet=right rear
green=left rear
white=right rear
speaker wire with black stripes is negative.
Sep 29, 2016 | 2011 Dodge Ram Pickup 1500
Need to know how to diable the security system on a 1998 subaru legacy outbak. At this point we cant get the car started because of the security system has us locked out
If it's an Alpine system; turn the ignition on,off,on,off,on,off. The car can start on the fourth turn. If it's a Cod alarm:
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button
Press lock (left) button the remotes to be programmed. The door locks will cycle one time.
Exit programming mode by releasing Programming button under dashboard and turning key to off.
Code Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Mar 30, 2011 | Subaru Vehicle Parts & Accessories
Need a wiring diagram for alpine ktp445 amplifier to install on no alpine system
bassmekanic_3.jpg For this end of the plug: I would plug the other end of the KTP-445 directly into it and match the color of the wires off the other plug, remember to write them down, but most of the wires look like standard plug wires on most stereo plugs. When this is complete you should be able to snip this end off. Then wire it the wiring harness inside the dash (using the notes you took on the wire colors)
bassmekanic_4.jpg This end of the plug looks to have all the standard wires that most after market stereos have, clip this end off and wire it to the wiring harness on your current stereo. (You may not use all the wires, just tape them off because you probably won't need them anyway)
This is just my opinion on how it would be done, I have not tried this myself. But since most aftermarket stereos have the same kind of wire set up I do believe this could work.
If you decide to try it, please give some feedback so others can figure out how to do this also.
Nov 09, 2010 | Alpine KTP-445 Car Amp
Wiring diagram
Well for a wiring diagram there isnt one. Really all you need to know is how to wire it properly. You can put it up to 8 ohms and all the way down o 2 ohms and possible 1 ohm. Check this website: http://www.bcae1.com/spkrmlti.htm
Dec 27, 2009 | Alpine SWS-1043D Car Subwoofer
How to Insall Alpine CDA-9805 in a 1992 Chevy S-10
did you purchase the additional wire harness adaptor kit? if you did the connector in the kit will pkug into you chassis harness coming out of the dash and the wires are color coded to the radio just splice it all together and install in the new dash kit you should have also purchased unless aftermarket radio was already in the vehicle, and rock on. let me know. ill help you out
Mar 07, 2009 | Alpine Car Audio & Video
Alpine mrv-1507
Your amp. got damaged the audio amplifiers IC's thats why it's going on protect mode.
Jun 05, 2008 | Alpine MRV-1507 Car Audio Amplifier
How to wire a stereo system
Connect the 2 gage to the battery thru at least s 50 amp fuse, then connect the capacitor in line before the amps. Then run the 2 gage to a connector/splitter block and run 4 gage leads to each amp. You also will need at least 4 gage ground leads from each amp to a body grounded bolt or screw. You need to run a quality set of speaker leads from the head unit to the amps. The speakers will need separate leads from the amp to each speaker.You will need to try some different combinations to get the sound and bass you want. You want to be able to fade from front to rear and control everything thru the head unit.
Use a hole saw to cut a 2 to 3 inch diameter hole in the side of the speaker box for a port to get a better punch from the sub.
Hope this helps some....
Nov 03, 2007 | Alpine CDA-7863 CD Player
Wiring diagram
Jun 06, 2007 | Alpine TDA-7563 Cassette Player
Car Audio & Video Logo
209 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
