Question about Fuji FinePix S5000 Digital Camera
Battery compartment door is ok but the teeth on the camera are broken. is this repairable?
  • 667 Answers
You would have to replace the inner housing to replace the latches.
Fuji USA might have a fixed rate for this, here is the link to the support page for the S5000: FujiFilm
Posted on Mar 25, 2008
SOURCE:
Can battery compartment be repaired when tabs are broken off which hold lid down?
possibly...if it is the body where the tabs are broken off the manufacturer (Olympus) might be able to replace the body shell. I'd check with them.
Aug 16, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
Battery door retaining lugs broken,also the plastic lugs on the main body that the battery door needs to latch onto are broken off ,cannot use camera as unable to secure batteries in the camera ,door will...
KODAK doesn't sell battery doors for any of their models.
A repair for this fault is 24,47 pounds + shipping to the repair centre.
If you already have the battery door; I suggest you will have a local camera TECH to attach the door to the unit.
Feb 04, 2010 | Kodak EasyShare C340 Digital Camera
Need to know how to repair easyshare c913 battery door has little metal piece connecting the battery -it is broken can i buy just the piece?
go to this website
http://www.uscamera.com/2f7049.htm
part for your camera
its a battery compartment for C813 which is compatible for your C913 Camera
Sep 22, 2009 | Kodak EasyShare C913 Digital Camera
I have a Fuji FinePix S5000 and the battery door catches (on the body of the camera) have broken off. Replace complete body assy??? I am sure mine is not the only one. any help appreciated.
I had this problem also (see below).
After getting poor results with the duct tape solution, I discovered another work-around. This should work whether it is chipped lugs on the door or on the body.
Firstly I used an old camera flash bracket that screws into the tripod socket, and this holds the battery door in place quite securely. However it was too long, so I cut and filed a piece of aluminium 25mm (1") wide by 2.5mm thick to the right length (around 100mm/4") and shape, and made a hole for the bracket screw.
End result is not exactly like new, but more functional than the duct tape and does not further damage the actual camera:
Mar 05, 2009 | Fuji FinePix S5000 Digital Camera
FE-140 Battery compartment door broken
you could try and put all the info about your camera in to google search..or the same on ebay.
Oct 27, 2017 | Olympus FE-140 Digital Camera
Need to replace battery comparment door
I have a c143 and my battery compartment door is broken . I tried duct tape but that didn't hold.
May 29, 2008 | Kodak EasyShare C315 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Battery casing went to put new batterys in case wont open tab has broke
If one of the teeth fthat engages the battery cover dorr has broken, use a piece of electrical tape to put over the door.
Feb 24, 2008 | Garmin StreetPilot i3 GPS Receiver
Broken battery compartment cover
The doors are about $20 on ebay. Heres a link for you:
http://cgi.ebay.com/KONICA-MINOLTA-Z6-BATTERY-DOOR-CAP-COVER-REPAIR-PART_W0QQitemZ170153738005QQihZ007QQcategoryZ64352QQrdZ1QQssPageNameZWD1VQQcmdZViewItem?_trksid=p1638.m118
Jan 03, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
323 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
