Question about Mpio FL350 MP3 Player
Cant turn on my mpio fl 350 because of discharged battery
Hi I have not used my player from last 1 month so the battery is discharged and Im not able to turn it on because of it and even not able to charge it
Hey! I experienced the same problem as you, found my FL350 wich had been laying in a closet for 2 years, completely discharged.
What I did, was to connect the FL350 to the USB port, a message popped up saying like "USB device can not be recognized", ignore it, it will keep popping up, but don't mind that. I then left the FL350 in my PC with the PC turned on, and left it over night. Today I could turn the MP3 player on, resulting in that the PC found the device and it began charging. So I will leave it there, and in two hours I will go out running, listening to it :D Hope this works for you.
Posted on Jul 20, 2010
How to Replace Battery in MPIO FL300
my mpio FL300 can't conected to my computer,because i've been format it.how to solve this problem?thx.(if ful)
Aug 16, 2009 | Mpio FL300 MP3 Player
Hi, I can no longer browse through the files of my MPIO MG 100.
ok what charge setting is it on? if its on the MTP setting hold the "MENU" down until a message apears that says "reconnect the mg100 to change the mode" then it should work. if not then i guess i wasnt verry helpful and im sorry
Jun 05, 2009 | Mpio Audio Players & Recorders
Hi, i dont have the disc that comes wuth tho mpio. how can i delete files that i recorded on it?
MPIO Utility can be used with MPIO player that supports USB Mass Storage.
With this, you can..
- Format and Recover MPIO player
- Upgrade firmware of MPIO flash-type player
- Building playlist of MPIO hdd-type player
* Supported OS : Windows 98 SE, ME, 2000, and XP
* MPIO Utility doesn't work with FL200 and FY300.
* If you are using the latest firmware, be sure to use the latest version of MPIO Utility.
* Please uninstall the old version of MPIO Utility before installation.
[Download] REDOWNLOAD NEW DRIVERS AFTER UNINSTALLING OLD ONE'S RICHARDM69
Dec 04, 2008 | Mpio FL400 MP3 Player
BRAND NEW MPIO HD300 Completely DOA!
It's a reasonably straightforward task. There are 2 screws at either side (near the top) of the player. You'll need a small Alan-key to remove these. Once this is done, carefully prise off the back cover and you'll be able to see the battery - at the back. Just un-clip the battery cable. - You might want to check the connection in the first instance, if however, the battery needs replacing see replacment battery model number below: -
UP325385A4H-UP325385A5H
Hope this heps
Nam1
Feb 21, 2008 | Mpio HD-300 MP3 Player
Help !!!!!
The VP-02 is based on the MPIO FL-100. You can get the MPIO manager software from www.MPIO.com. The latest version is MPIO manager version 2 buils 1.8.0.0
Jan 06, 2008 | Virgin Pulse VP-02 MP3 Player
I cant play music
i need to reinstall roxio
Aug 10, 2007 | Mpio FL400 MP3 Player
Deep trouble with the memory..
ok you have to format by itself. reset the fl400 by the pinhole then when its off press play and menu at the same time for 10 seconds then press and hold the rec or rew button. after the format, run mpio utility press on setup & conf now you havet it like new
Jan 18, 2007 | Mpio FL400 MP3 Player
MP3 Player Won't Turn On
im having the same problem
Jan 11, 2007 | Mpio FY500 MP3 Player
No disk to install software
The VP-02 is based on the MPIO FL-100. You can get the MPIO manager software from www.MPIO.com. The latest version is MPIO manager version 2 buils 1.8.0.0.
Dec 02, 2006 | Virgin Pulse VP-02 MP3 Player
Mpio HD-400 is stuck on loading screen windows doesnt recognize it
alotita, I have an MPIO HD-200. Does Windows play the sound like you have something attached when you plug it in? Or does Windows not regognize it al all? Either way, I've had to play with mine after I've dropped it a couple of times. I charge the battery all the way, then just keep plugging and unplugging from the USB wire. The last time, it took 20+ times before Windows would recognize it.
Nov 14, 2006 | Mpio HD-400 MP3 Player
Mpio FL350  MP3 Player Logo
293 people viewed this question
Top Mpio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
