Question about Radio Shack Pro-2096 Base Scanner
I am looking for the cheapest way of recieving 66.6 on any scanner..........can you help
    President:
  • 2,761 Answers
Sorry, but that frequency is out of the tuning range of virtually all current scanners. About your only option is to purchase an old continuous-tuning scanner such as the PRO-2006, ICOM IC-R71, etc. eBay is possibly the best source.
Bill B
Posted on Apr 30, 2010
Testimonial: "thx for the info thats me hours or homework,"
  • Bill Buchsbaum
    Bill Buchsbaum Apr 30, 2010
    The ICOM IC-R71 is actually an HF receiver. The IC-R7000 provides continuous tuning of the VHF band. My apologies for the bad info.
    Bill B
Tip
Good Way to Test Your Radio Scanner
If your Radio Scanner recieves Aircraft Frequencies and you live about 20 miles from an Airport you can look up the Frequency of the Automated Weather Beacon of the Airport which should be transmitting all the time.
on May 19, 2010 | Radio Communications
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Radioshack pro 2067 will not recieve anything
Make sure its your local weather channel, turn squelch to minimum, get your local frequency at www.RadioReference.com ...hope this was helpful...
May 26, 2010 | Radio Shack Pro-2051 Base Scanner
To get celluar frequencies on bc350c 800mhz 100 channel scanner.
Jason,
You can no longer listen to cell phones with police scanners as all cell phones are now digital. Years ago when cell phones were using the 800mhz band it was possible. But only with select older models of scanners such as the BC-200XLT and after an internal modification to allow tuning of 860-880 mhz range. I do believe there is equipment out there that can listen to digital cell phones but its very expensive ($10,000) and only for law enforcement use. Hope this answers your question.
Oct 09, 2009 | Uniden BC350C Base Scanner
Cannot for the life of me figure out how to program this!
You need to obtain local frequency numbers for your area.
google search, "radio frequencies" and you county, city name...it'll give you lists of frequencies to enter into your scanner..
Your user manual should show you the step by step with which buttons to push... are you having difficulty entering the frequency numbers?
k
Jul 06, 2009 | Uniden BC60XLT Handheld Scanner
Free scanner frequencies
i recently bought a uniden bc72xlt and had no freqs. found some for my area at these sites.try www.scanner master.com*-frequency resources and home of police and call,www.radioreference.com,www.bearcat1.com,hope some of these sites help you out.
Nov 07, 2008 | Radio Shack Pro-95 Handheld Scanner
Vertical clear lines on the recieving end
My suggestion is if it only happens from that fax then there scanner has a problem.
Not familiar with that model but there are only two ways that i've seen.
1- scanner is located on the bottom side of the buttons. lift menu door, look inside there is a thin strip of glass clean, look on the top side there is a white plate, clean
2- open machine take out toner look on bottom of machine there is the thin glass of clean.
Dec 07, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Radio shack pro 2055
Hi, My first guess with the limited info is, either you have the attenuator turned(which is like an RFgain), or you have a defect in the antenna or coax(if it's mobile.) For the attenuator see pg.66 of your manual.
I assume it's picking up your ham radio when you key it, but at close range it'll pick it up without an antenna.
I hope this helps you sort it out,, Mechanic
Dec 01, 2007 | Radio Shack Pro-2055 Base Scanner
No recieving
sounds like the reciever is getting hot? try bringing it to a local radio shack dealer and see if they will have there techs. look at it.
Jun 10, 2007 | Radio Shack Pro-2018 Scanner
Radio Shack Pro-2096 Base Scanner Logo
136 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
