Question about Sony Audio Players & Recorders
Hi,I have a Sony STR-D990 Receiver,and when I plug in power I see light on volume knob only, no other light turns on like the display etc. Please for some ideas on what i can do to fix this amp ,it's old but it's my only one ,I would appreciate any help ,what can I check I mean like fuses etc please for ideas and advises ,help me please ,and have a wonderful day. David.
I had the same problem with mine. Turned out to be a bad solder connection on the Printed Circuit Board on top of the power transformer towards the rear of the reciever. If you flex the board by the connector going to the display you might see it come and go. I resoldered the connections and now all is good.
Posted on Apr 30, 2010
Need to replace volume knob
Did mine years back - need to find part RV1802 1-418-773-11 ENCODER, ROTARY (MASTER VOLUME)
Volume went up and down turning in one direction. About 2 hour job, pull both knobs off, remove cover and front plate to get to volume switch assembly, replacement part requires desoldering and solder on new part.
Nov 24, 2013 | Sony STR-DE1075 Receiver
Hi, i have problem with my Sony STR-DG820, front display is broken, is any chance get new one from somwhere, everything is working except of this thanks
I had a broken knob on my Receiver and was able to find one from a printer place. I am pretty sure he can find the part you need.
perfectprinterparts@gmail.com
Michael
Jan 16, 2011 | Sony STR-DG820 Receiver
Sony str-de845 powers on, relay clicks sound works for a few minutes then relay clicks again and sound stops. display stays on.
Hi there, can anyone help me? i cant seem to get my aiwa-d58 to get out of eco mode. no power, red light is on and every time i press the power button; the eco light clicks off and i no power supply to the whole unit. please help!
Jan 22, 2010 | Sony STR-DE845 Receiver
HI, WHEN I TURN UP THE VOLUME THE DISPLAY SAY'S PROTECTOR POWER OFF AND THEN IT WORKS TILL INCREASE THE VOLUME THEN IT COMES ON AGAIN. ARE THE SPEAKERS TOO SMALL??
disconnect all speakers and try volume on its own.Then try one speaker at a time and increase volume this will help you if one speaker is bad.If unit acts up no matter what you do ..Then theres a good chance you need to send it to a shop .Try to find one thats sony authorized..thanks
Aug 05, 2009 | Sony STR-D965 Receiver
Low sound at high volume
THe problem is with the variable resistor present behind your volume control knob, try replacing the volume controls variable resistor, this must work fine... this is a common prblem for all the music equipment that has knob control for the volume....
This resistor can be replaced with your product warranty, contact your seller for the details regarding warranty...No need to woory about this, this is a sommon problem for most of recievers
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Jul 04, 2009 | Sony STR-DG1100 Receiver
Output
When you change the selector switch, do you hear the relays inside the unit? Is your muting button activated (found to the lower left of your volume knob)? Do you have speakers connected to A or B or both?
Dec 23, 2008 | Sony STR-DE685 Receiver
Sony STR-DE635 Receiver-no sound at all
sorry my expertise is in appliances, youl need to repost you question to another tech
Mar 21, 2008 | Sony STR-DE635 Receiver
Turn your volume down,press the tape monitor button.then turn up?
Mar 20, 2008 | Sony STR-DE635 Receiver
No display
it is a bad fuse or the i.c. chip is bad
Jan 02, 2008 | Sony STR-GA8ES Receiver
422 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
