Question about YouTube Videos
GE TBX25PASHRWW WATER DRAIN CLOGGED
GE TBX25PASHRWW WATER DEFROST DRAIN CLOGGED
    Problem Solver:
  • 11 Answers
This Isn't Your Model But It Is Basically the same
<object data=http://www.paulstravelpictures.com/How-To-Fix-A-Leaking-Refrigerator/index.html width="600" height="400"> <embed src=http://www.paulstravelpictures.com/How-To-Fix-A-Leaking-Refrigerator/index.html width="600" height="400"> </embed> Error: Embedded data could not be displayed. </object>
Posted on May 01, 2010
My GE Profile refrigerator leaks water from the freezer. I find a puddle under it 2x/week.
Defrost drain tube clogged, drain pan cracked, water tubing near compressor gets brittle and leaks, critters chew on water tubing also.
Oct 29, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
Problem with the GE Monogram ZISS420DMSS Side by Side Refrigerator. Defrost Drain tube clogged. Icicles form in the frezer compartment. How do I fix? Thanks.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 17, 2011 | GE Monogram® ZISS420DMSS Side by Side...
Older ge refrig, freezer at top leaking water into refrigator compartment below. otherwise its working fine.
Its the defrost problem. The drain hole is clogged and water is leaking in fridge section instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/ge-refrig-freezer-at-top-leaking-water.html --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Refrigerators
My GE fridge is leaking water on the freezer side
This would be due to the defrost drain being clogged. The automatic defrost cycle melts the frost on the evaporator every few hours and the water from that is suppose to flow down a drain tube, if the drain becomes restricted the water will leak out the freezer door. Here is a link to some instructions I put together on how to clean it out.
Defrost Drain Cleaning
Jul 18, 2010 | GE Refrigerators
Water leaking out the bottom of the freezer even when water is shut off
The defrost drain is clogged causing the water from the defrost cycle to flow down to the freezer floor. The defrost drain and drain trough are located behind the freezer panel at the back of the freezer wall inside. Remove this cover to get to the defrost drain and remove ice. Do not use any thing that may puncture or damage the evaporator coils because this is what you freon flows thru to do your cooling. Thank you for using fix ya.
Feb 04, 2010 | GE Refrigerators
Ge side by side model tfx27pfx. Ice maker not
Your defrost drain hole is clogged. Turn the fridge off. Defrost the drain hole in the freezer. You will be fine until it does it again.
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model tbx18mazarww refridge. Water coming from behind the temperature control panel. Defrost line is not clogged
Your defrost line coupling , is blocked from inside the freezer , to the defrost line behind the refrig . You will have to remove the inside rear freezer panel and icemaker if equiped , and defrost the drain hole in the center below the coils . Hot water will help .
Sep 24, 2009 | GE Refrigerators
Clogged defrost drain on GE side by side
yes you do pull out the bottom back panel of the freezer to access the drain then use hot water or a hairdryer to thaw it
Feb 11, 2009 | GE Refrigerators
On TCD18PAD BWW refrig with freezer (drawer, not door) on bottom, water accummulates in bottom of freezer and freezes into ice which some how thaws with water flowing out bottom of drawer door onto kitchen...
You have a clogged defrost drain tube. On the back of the refrigerator in the center, about two feet above the floor, is a 7 inch by 7 inch square steel cover held on by four screws, one at each corner. The defrost drain tube emerges from the bottom of this cover and terminates loose in the drain pan below the refrigerator. Remove the cover. Underneath is the plastic defrost drain tube fixture, which is held by two screws. Remove the screws and take off the drain tube fixture. This fixtue is clogged. Run hot water and dish detergent through it and blow through it at the big end to remove the clog. Reassemble. That's it. You don't have to take the refrigerator apart. One caution. When the refrigerator has a clogged drain tube, the defrost water will back up and freeze around it. So you may need to empty your freezer and unplug the refrigerator for eight hours or so first before you perform this procedure to allow all the ice around the clogged drain fixture to melt.
Aug 31, 2008 | GE Refrigerators
YouTube Videos Logo
196 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
