Question about Kenmore Oasis HE 27082 Top Load Washer
  • 6 more comments
  • Anonymous Aug 30, 2008
    I recieve F1 on the screen and the washer stops.
    So what do I do?
  • gibson1152 Aug 30, 2008
    My screen says F1 and the washer stops. What do I do?
  • nctigger1971 Sep 20, 2008
    It i hit stop the restart it may wash or it may stop again do ytou know what the problem is?
  • rastone390 Sep 21, 2008
    Has anyone found a solution? I'm having the same problem.
  • Anonymous Sep 22, 2008
  • irmagt Oct 30, 2008
    I have the same problem - what's the fix?
  • vlh1966 Nov 01, 2008
    I have Kenmore Elite Oasis 27032602 and it gives the F1 error message. It will sometimes finish the cycle when the load is 'rebalanced.' Now it is doing it for frequently and I am sick of it. What is the problem on this particular model?
  • hopehill22 Nov 02, 2008
    I have the same problem...It seems to happen when it locks right after I start a load. Very irritting!!
  • 185 Answers
Thats not the model number
Posted on Mar 26, 2008
I found this information related to a different model of the Vacmaster:
If you see F1 displayed on the LED screen and the machine will not function, make sure the lid is open and turn the power off. Turn the machine back on and it should return to working order.
Mar 25, 2013 | Vacmaster Vacuum Pack Machines: VP540C...
F1 error appears just right after I turned the machine.. I had to stop and tstart 3-4 times before it gets on to cycle. Then at 23 minutes F! error error comes back and I had to do the same thing (stop and...
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 28, 2011 | Kenmore Washing Machines
It has an F1 error code. It will start the water flow for about 2 seconds. Stops and beeps f1 on the screen. I hit the stop button and start again and have to repeat this 3 times before the wash machine...
The manufacturer has issued a remedy for the F-1. What you do is empty the machine of water and unplug it. Open the control panel and remove the pressure hose. Blow out the hose to remove sediment . Re secure it to the control and retry. No parts needed. F-1 Error infothemobilian_1223.jpg
Feb 01, 2011 | Kenmore Oasis HE 27082 Top Load Washer
As i turned on the monitor the screen shows CMOS WRONG PRESS F1 TO SETUP PRESS F2 TO LAOD DEFAULT VALUE
first of all check the main battery back of ur machine by unplugging from the mains power supply. if machine shuts off, then u have to replace the battery.and then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
if the main back up battery is ok, then another possibility is the CMOS backup battery of ur machine have some problem. that's why it loosed all the seted parameters. then u have to replace the CMOS battery of ur machine. normally 3V battery. then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
Jan 13, 2011 | Dmm UT4000F Multi-Parameter Patient...
F1 error
yep electronis control board in the console is bad.
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Fisher& paykel F1 Fault code
F1 means u have a leak on the machine somewhere. they leak from , lid, drain hose , lid activatiors, the leak has flood sensor to come on. to stop the F1 code u have to repair leak. please reply 4 more help.
Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Code F1
Hi. this is a serious control fault that incorporates many situations. This (F) code calls for a service call. there may be a combination of control and motor faults here. if you own a multimeter(ohm), i would start by testing the control panel connections. if you are uncomfortable with disassembling this machine, i suggest making a quick service call. If you have any questions,please feel free to ask.
Please rate and god bless.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal De
 Brian Main
Brian Main
