Question about Logitech QuickCam Communicate STX Personal Web Camera
Logitech web cam
Logitech webcam says it is in use by %appname% says to stop %appname% and reconect but dont know how need help
  • 1724 Apr 04, 2008
    My Logitech webcam pro for notebook is saying the same thing (says it is use by %appname% says to stop %appname% and reconect) but dont know how need some "HELP"
    President:
  • 2,712 Answers
Removing the software and reinstalling it using a "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4. Locate the listing for the software and remove it. When prompted to remove the camera drivers files, click Yes.
Now download the latest version of the software for your OS from HERE. (Dont worry if the picture of the camera looks different, its all the same software. Just choose your correct OS from the drop down menu.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next , do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Apr 26, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
I need a driver for a Logitech web cam/mic combo. Don't have a model name only a serial # LZC51451368
hi can you tel how your webcam look like , just go to this site and tel the name it have all logitech web came.
http://www.logitech.com/en-in/support-downloads/downloads/webcams
Dec 31, 2010 | Logitech Webcam
"HELP ME TO HOW TO DOWNLOAD DRIVERS OF LOGITECH WEB-CAM"
http://www.logitech.com/en-us/support-downloads/downloads/webcams/devices/222?WT.z_sp=Model
Jul 15, 2010 | Logitech Webcam
I need to install a logitech webcam but i dont have cd anymore
Go To the Logitech web site and select downloads and drivers . Follow the directions and it will ask you for your web cam model number and then it will allow you to download the drivers for your web cam.
May 13, 2010 | Logitech Webcam
I have a web cam but i dont have the software?
you need to know your webcam model check if your webcam have some number printed, so we can help you to find your software online
Regards
manish
Mar 23, 2010 | Logitech Webcam
Veo webcam free software 323vb25x i whant to know how i can instoll because when i buy they tell me i dont need the cd
Did some research and here is a link for your web cam software. Logitech says that the Logitech Vid will work on most web cams including yours.
Click on the blue download button.
Hope this helps.
http://www.logitech.com/index.cfm/349/5788&cl=us,en&pcid=5787
Nov 10, 2009 | Logitech QuickCam Express Web Camera
I lost my webcam cd installer
how can i download cd installer of my logitech webcamilost my webcam cd installerhelp me sir/mam: i lost my cd of this webcam, my brother wnt to see soon....thank you I LOST MY CD OF THIS WEB CAM PLC HELP ME i have a web cam logtech lost the manual for it cant get my web vam to work help me i have a new logitech webcam but i dont have a intaller how can i use my webcam?
May 31, 2009 | Logitech Webcam
Lost my instalatin disk
I have lost my installation disk and i dont know how to set up my web cam for a logitech quickcam messenger
Sep 18, 2008 | Logitech QuickCam Messenger Web Camera
how can i install I lost my cd installer
Aug 16, 2008 | Logitech QuickCam Messenger Web Camera
Lost my webcam installation cd
Click HERE to get Logitech drivers for your webcam.
Jun 04, 2008 | A4tech Xmaster PK-835 Webcam
My logitech quick cam
The disc you need is called a driver  ,  you could download this program from limewire , just 1st try to download any logitech driver , if that doesnt work please message me and i WILL  find out the model of your cam , bye hope i   helped :)
Oct 17, 2007 | Logitech QuickCam Messenger Web Camera
Logitech QuickCam Communicate STX Personal Web Camera Logo
260 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
