Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Door will not seal nothing is blocking it it seems to have no vac seal on the door like the freezer
  • 33 Answers
One the seal is going bad. But most of the time your floor is not level or shifted move your frig alittle it will work mine did samething
Posted on Apr 29, 2010
Can I replace insulation in door only?
Hi - I understand that you recently had something heavy drop on top of your Frigidaire Freezer door. From my experience the condensation does typically indicate poor door seal. When cold air and warm air outside is entering into the freezer it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit. Hope this helps! JK
Oct 21, 2015 | Frigidaire 5 cu. ft. / 142 liter Chest...
Condensation on top of freezer. It got something very heavy dropped on it. Dented the top corner. Door seal gasket IS sealing properly. is there a way to re-insulate just the door?
Hi - I understand that you recently had something heavy drop ontop of your freezer door. From my experience the condensation does typically indicate poor door seal. When cold air and warm air outside is entering into the freezer it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit. Hope this helps! JK
Oct 21, 2015 | Frigidaire 13 cu. ft. / 368 liter Chest...
Vacuum light on?
In 90% of the times, from my 5 years experience with subzero repairs, it will be leaking evaporator coil, compressor will run longer then suppose to (it still might keep temp). But first You need to check on all fan motors if they run. Also visually check if there is any snow or ice builds up in freezer and refrigerator compartments. if everything looks normal, then You need a serious repair. Here is video I made how to replace evaporator coils. Hope that was helpful!
Mar 07, 2015 | Sub-Zero 650 / O Bottom Freezer...
How to fix a chest freezer seal
Hello friend, I appreciate your post!
I see you are trying to fix the seal on your Frigidaire chest freezer. Are you having an issue with your freezer not closing? If so, have you verified that there is nothing blocking the door from closing as well as making sure there was nothing between the door gasket and the freezer body? Next, I would check to make sure that the gasket is not damaged or compromised in any way. If it is not damaged, I suggest contacting your local authorized technician for further assistance. I hope this information helps. -Matt
Jul 22, 2014 | Frigidaire 13 cu. ft. / 368 liter Chest...
Frigidaire Freezer Model FFU17C3AW1 door not sealing properly?
Good Afternoon Vonaspern,
I understand that you are having trouble with the door sealing properly on your Frigidaire freezer, model# FFU17C3AW1. I see that you have already checked to make sure there is nothing blocking the door from closing as well as making sure there was nothing between the door gasket and the freezer body. Next, I would check to make sure that the gasket is not damaged or compromised in any way. If it is not damaged, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your freezer and determine what is causing your appliance to properly seal. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer door does not make vac sound
Might need a new seal.
A better test than sound is the put a dollar bill in sealing area and close door. Check how hard it is to pull dollar out (check tightness).
Do this all around the door in various spots.
Jul 22, 2013 | Freezers
Freezer door doesn't close all the way on one side,
Make sure that there is nothing blocking the drawer on that side. If there is nothing there carefully inspect the drawer closure. There should be a little catch point when closing the drawer that makes it pull closed on it's own. If you are still having an issue you will want to replace the rail/slide assembly.
Jun 13, 2010 | LG LRFD25850 French Door Refrigerator
Freezer door pops open
there's nothing wrong w/your dr seal. add a then layer of silcone or vaseline to the seal. this will make it sticky again.
Jul 14, 2009 | Refrigerators
Frost in Freezer, front of shelves
Sometimes enough ice will accumulate at the front of the shelves to actually block the door from closing completely. Are you in and out of the freezer often? Moist air that hits the frozen shelf surface will accumulate at the front of the shelves first because that's where it hits first. Check that the freezer is level and plumb not on a "twist". If it is sometimes the door will not seat properly and therefore leave a gap for air to get in. Take a dollar bill and place it in the door seal surface. Close the door and try to slide the bill out from between the door frame and the seal. Do this in several places around the door. If it comes out with little or no friction you may have found your problem. Finally, completely defrost the freezer shelves after removing all the food. Don't poke or dig with an ice pick or screwdriver or you will poke a hole in the tubes and ruin the freezer. You can speed things up with some hot water in a pan placed inside the freezer. Be ready with towels or pans to collect water. Good luck!
Jun 26, 2009 | Kenmore 64802 Top Freezer Refrigerator
Freezer door opens
its air pressure between the wo doors that cause it to open the freezer door.take some soapy water and clean the sels aroundboth doors to see itf thet dosent help use dish soap and a little water to clean the seals with it should stop it
Jan 07, 2009 | Frigidaire FRS3R5EMB Side by Side...
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
57 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
