Question about Philips 55P8341 55" Rear Projection Television
Phillips model# 60p8341
My tv does not show a picture when the power is on, it will show a brief picture when the power is turned off. Is there a problem with my projectors? how do i fix this problem?
  • 1,153 Answers
Let me get this straight, you don't have a picture as long as the unit is on, but when you go to turn off a picture flashes? Questions, first how is the picture when it flashes briefly? Is it normal or with colors misaligned? How is the sound? Could be a loose connection or bad capacitor in the video circuit.
Posted on Mar 25, 2008
Westinghouse ew32s5kw tv red light shows power is going to unit pressing power turns indicator light from red to blue for a brief moment then back to red.
I had the same problem on my Westinghouse 32 inch TV. The internal main power supply went bad and had to be replaced. I had a TV repair shop do it. It was about 8 years ago. Haven't had a problem since. I think it cost about $70 for parts and labor. Nowadays TVs are pretty much a throw away item if they go bad. TV repair shops are getting hard to find plus the cost of TVs has come down so much sometimes you can get a new set for what the repair would cost!
Oct 25, 2017 | Westinghouse Televison & Video
The projector would not turn on and had a flashing red light for the lamp. Knowing it was an older projector when we rented the building I purchased a new bulb for this projector. When I put the new bulb...
PROBLEM :-The power supply of the projector is faulty there is a transistor witch is switch 15 volts for the lamp drive board.
SOLUTION: Remove the upper cover with 6 screws back side of the projector.
remove main board and lamp cover with 7 screws.(show in the picture)
remove upper cover of the power supply and lamp drive unit with 3 screws.
remove power supply unit with 4 screws and 3 connectors and put face down on the table.
now you find the transistor no Q107 and replace with the transistor no 2SB710 is and surface mounted compunent(show in the picture)
fix it all as you open.
power ON the projector and enjoy
(doing very carefully This is a technical job)
Feb 05, 2011 | Panasonic PT-LB10SVU Multimedia Projector
Turn Power Off by pressing power button on projector, it is now in standby.
If projector is plugged in but not in power On mode or not showing picture, it calls standby.
Aug 27, 2010 | Sony VPL PX40 Multimedia Projector
InFocus Projector-Searching
most likely it is your cable. If a for sure brand new cable doesn't fix it it is most likely the main board. Also try flashing the software again.
Apr 28, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
When i switch tv on, it shows picture for 5 seconds then goes into standby. the tv is a vistron ltm-3271e lcd
The problem is associated with the power supply that cannot run under load. The showing of picture for a brief period of time indicates that the main board, ballast, inverter and panel drive are all OK. The unit turns on but the power supply cannot sustain the power requirement of the unit and shuts down.
The usual culprit on the power supply are blown or bad capacitors. Check the power supply for such capacitors. If no apparent damage or defect is found, replace the power supply.
Nov 07, 2009 | Televison & Video
Replaced lamp now projecter will not turn on hd70
I had a similar situation, but we fixed it.  I can't exactly tell you why it worked nor whether or not it will for you.  Here's the deal.
First, take your lamp out and re-seat it.  This is one of the easiest ways to get a projector not to power up.
In our case, the thing would fire up, show us the Optoma logo, the blue screen, and then within about 15 seconds, it shut down, lamp fail light came on, and only a hard power reset would let us try again.  The bulb was good; after all, it came on, right?
So, we kept playing this game of power up, fail, unplug, replug.  I gave up and went to do something else.  I came back to the projector, needing it to let me see a screen to configure (weird I know, but that's how it was).  Anyhow, at this point, the projector stayed on, no problems.  So, I kept it running through the night with a kitchen timer on.  After 5 1/2 hours without failure, we knew we were set.
The point?  If it's powering up and showing picture for even a brief period, try cycling it several times.  However, if it's overheating or showing any other signs of distress, you may make it worse using my approach.  I think we may have just been lucky or the projector gnomes came in the night.
Jun 25, 2009 | Optoma HD70 DLP Projector
Sharp XGE3500 Projector won't stay turmed on
the power supply is starting to go. the caps are drying up. if there is a large drain of power (like striking the lamp), it'll shut down.
Mar 02, 2009 | Sharp CLMPF0046DE10 Projector Lamp for...
New Lamp, still no picture
You may want to call in for service, the red lights mean that there is a temperature problem internally.
Dec 01, 2007 | Hitachi CP-S225WT Multimedia Projector
Model; P52750WK serial; 340486076
Hit remote power button. Brief " crackling " sound, no picture. No problem with TV since new. There is a brief spark like light with sound.
Nov 21, 2006 | RCA P52771AT 52" Rear Projection...
Philips 55P8341 55" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
