Question about Fuji FinePix F460 Digital Camera
Some buttons have stopped working the menu down arrow button zoomhave stopped working and the situatiob is worsening
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 59 Answers
Your great little camera is indeed sick, sounds like dirt or liquid got inside the button area. I suggest downloading the manual, and if it looks like something you are capable of and have the time, taking it apart and cleaning it, if you are not successful you are not out much as it was already not working, with the possibility of success! if dirt or water got this far it may be going for other parts also, so inspect carefully, about half the cameras I've had apart are repairable within reason. Amazon has these for;
new from $129.95
4 used from $40.00 Hope this helps
Posted on Apr 29, 2010
Printer error fuser temp
You can find answers to Xerox questions at www.xerox.com/support
Solutions for : Printer Error Fuser Temp Message There are two configuration options available for this model; the Phaser 3100MFP/X and the Phaser 3100MFP/S. Fax features are only available on the Phaser 3100MFP/X. To determine the configuration of your machine, print a Configuration Page. See the Related Items below for additional information.
Solutions ranked by relevance:
  1. Make Sure the Power Cord is Securely Connected to the Machine and the Electrical Outlet
  2. Make Sure the Machine is Plugged Into a Functional and Stable Power Outlet Test the power outlet that the machine is plugged in to by connecting another device to the outlet. Make sure the outlet is functional and stable. If possible, have the line tested by an electrician. If necessary, plug the machine into another power outlet.
    NOTE: The machine should be plugged directly into the wall outlet, and should not be connected to an extension cord, power strip, or Uninterruptible Power Supply (UPS).
  3. Reset the Fuser Error Solution : Reset the Fuser Error CAUTION: The following solution will put the printer in the Diagnostics mode and is only valid for this problem. Follow the steps carefully; any deviation from the process can cause other settings to be changed and / or render the machine inoperable.
    If at any time it is necessary to cancel the procedure and start again with step 1, press the [Stop] button four times.
    NOTE: This procedure will delete all pending jobs that have been sent to the machine.
    To reset the Fuser error:
    (Click on one of the following links to jump to the corresponding section.)
    To reset the Fuser error for the Phaser 3100MFP / X
    1. Press the [Down] arrow (Menu) button on the Control Panel.
    2. Press the asterisk [*] button.
    3. Press the pound [#] button.
    4. Press the [OK] button.
    5. Press the [1] button. ("00100001" changes to "10100001" at SOS1)
    6. Press the [OK] button.
    7. Press the [Stop] button.
    8. Press the [Down] arrow (Menu) button.
    9. Press the pound [#] button.
    10. Press the [T] button on the keyboard. (Do not use the numeric keypad.)
    11. Press the [OK] button.
    12. Power the machine off, and then power the machine on.
    13. Press the [Down] arrow (Menu) button.
    14. Press the asterisk [*] button.
    15. Press the pound [#] button.
    16. Press the [OK] button.
    17. Press the zero [0] button. ("10100001" changes back to "00100001" at SOS1)
    18. Press the [OK] button.
    19. Press the [Stop] button.
    20. Make a copy to check machine operation.
    To reset the Fuser error for the Phaser 3100MFP / S
    10. Press the [Down] arrow (Menu) button until "T>>Printer" is selected.
Nov 27, 2013 | Xerox Phaser 3100MFP/S Laser Printer
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
How do I set the time and date on a Panasonic DMC-LZ4
1. Press the menu/set button. This will bring up a menu.
2. Press arrow left (the button left of the menu/set button).
3. Press arrow down (the button below the menu/set button). This will select the setup menu (so, a wrench icon should be brighter than an icon of a camera).
4. Press arrow up or down (these buttons are above and below the menu/set button respectively) to highlight clock set.
5. When clock set is highlighted press the right arrow button (button right of the menu/set button).
6. Press right or left to select what settings you want to change.
7. Press up or down to get numbers according as you want them.
8. Repeat 6. and 7. as desired.
9. Press menu/set several times to exit menu options.
Feb 28, 2011 | Panasonic Lumix DMC-LS80 Digital Camera
Printe error fuser temp
Solutions for : Printer Error Fuser Temp Message Solutions ranked by relevance:
The first two should be simple to check; hjereis some help with the third option.
Trust you find this helpful. :)
Dec 10, 2010 | Xerox Phaser 3100MFP/S Laser Printer
I have Phaser 3100MFP/X This printer has 1 problem, problem is "fuse temp error" i cant fix this thing. 3100X is different 3100MPF can you help me to fix. Sorry about my English. Sincerely
To try solving the error: CAUTION: The following solution will put the printer in the Diagnostics mode and is only valid for this problem. Follow the steps carefully; any deviation from the process can cause other settings to be changed and / or render the machine inoperable.
Hope it works for you. Don't forget to leave your feedback. This can help others.
Nov 16, 2010 | Office Equipment & Supplies
"printer error fuser temp" this message comes after powering on the machine. how I can solve or what is the main problem of this error message? The printer is New I just buy it three days ago. please any...
Due to the fact you just got this Printer as new then you should be covered by warranty and the best would be to have someone from Xerox to have a look at it if the message continues.
If the solution below does not work you can attempt a firmware upgrade. You should be able to download firmware and instructions from HERE
  • To reset the Fuser error for the Phaser 3100MFP / S
Aug 30, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Problem for Sony SDM-HS75/B (Black) 17" LCD Monitor Menu buttons don't work but menu randomly appears
Try this:
Under the menu options, there's Menu Lock. Switch it to "On". It worked for me.
My menu button wasn't working, so to access the menu, I had to hold down the arrow up button and push the arrow down button till I got to the Menu Lock Option.
Dec 30, 2009 | Sony SDM-HS75/B 17" LCD Monitor
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
Haier LCD TV
Follow these instructions to the "T". On step 13 use factory on the right menu block instead of the left.
The procedure resets your monitor to factory setting on the boards an eeprom. It may or may not work if you have a bad component.
1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Apr 15, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Transmission Verification Report
HI Shelia. THere is a button marked as "function" on your fax machine and got to "set up". Press that and select the "print out" group. When you get in there you will see "reports"... select that and it will let you get into your reports mode. Make sure you have transmission turned off. You can set it up to print out every 50 faxes...that seems to work best for most people. You may have to dig around in those menus...but its in there. I just don't have one sitting in front of my right now. If you still can't find it, email me back and I will look monday when I am back at the shop.
Nov 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Fuji FinePix F460 Digital Camera Logo
240 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
