Question about Dishwashers
My whirlpool ADP6000WH starts but after a minute or so just makes a buzzing/humming noise. In the past it would sporadically kick into life after a certain time but its not doing that now, just the buzzing noise. Any ideas?
  • scottclewley Apr 29, 2010
    Hello 'SilverDragon'
    It appears that its the drain pump thats causing the problem, put the inlet into a glass of water, connected 240v but nothing came from waste pipe, it just hummed. sorry i should of said the problem happened even at start of new programme. Do you think i have hit the nail on the head, or do you think it could be something else?
  • scottclewley May 08, 2010
    Hi Macmarkus.
    It is a sticking washer pump causing the problem, i have ordered a new one.
    Many Thanks.
    Scott
    P.s silverdragon was way off with his diagnosis!
  • Dishwashers Master
  • 2,605 Answers
Hi, First off you need to determine if it is filling with water and then the "buzzing" sounds starts or does it not fill and the noise begins immediately. If it starts right away before filling, its a faulty water valve. If it fills and then the noise starts, it is either something stopping the wash motor&pump from starting, or the wash motor is faulty or seized. The later is common unfortunately and based on your description of this happening periodically in the past and then starting, it sounds like a seized/faulty motor&pump assembly. I was unable to locate the model number you provided, but if you can tell me its approx. age I can tell you how to check the pump. I'll look for your reply here. Macmarkus :)
Posted on Apr 29, 2010
  • 12,061 Answers
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=233 http://www.mediafire.com/?7eonemsxyyd
Above two are service and repair manuals. Below, is a DIY dishwasher help site. If the above doesn't work.
http://www.repairclinic.com/Dishwasher-Repair-Help
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Loud humming noise
try using a spirit level to make sure unit is sitting square,the most common cause of noise.....(also make sure its not touching the wall....)
Apr 13, 2010 | Whirlpool ED2FHSS Side by Side...
Buzzing/humming noise with jenn-air bottom freezer
i have this problem too on my GE Profile. A youtube video seems to suggest a compressor problem. Turn off the fridge for a while and let it cool down and try again? I tried but to no avail. Would someone answer this? Please :)
Mar 21, 2010 | Jenn-Air Refrigerators
Have a Toshiba 42hm66 and it has started to make a humming/buzzing noise. At first it would make the noise for a few minutes and then quit...now it does it the whole time the tv is on. Any ideas?
Sounds like a fan getting cought on some dust inside you might want to have this serviced if you do not know how to clean it.
The humming would be a fan the buzzing would be the fan getting stuck!!
Sep 17, 2009 | Toshiba 42HM66 42" Projection HDTV
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Buzzing noise
The buzzing you are experiencing is most likely the electric valve solenoid coil.
That is the valve that lets gas in when the stove is turned on.
Another source of buzzing/humming can be a mechanical clock, if hter is one.
If it is digital, then it woul not make noise.
May 20, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
May 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwashers Logo
93 people viewed this question
Top Dishwashers Experts
