Have a panasonic 47" HDL projection tv..under 5 years old model # pt-47wx53g, chassis Ap 825,manufactured August 2003 Purchased Oct. 2003. Have cable service..TV works fine until 2 weeks ago. Screen went black and no audio. When I try to turn the tv on 3 red blinks push off get 3 red blinks, infact get 3 red blinks nothing for 10 seconds & get 3 red blinks ongoing??? can't turn on or off
  • Anonymous Mar 15, 2014
    what I need to know is how do I get rid of the 5 red blinking lights on my pt-47wx53g tv
  • 8,617 Answers
3 blinks means the convergence circuits are shutting the set down. Usually the convergence ICs will take care of the problem, but I would recommend getting the service manual from the following link, as they will provide you free support to help you diagnose why it wont start as usually the convergence ICs wont prevent a set from powering up, unless another component in the convergence circuit has failed.
http://servicemanuals.vstore.ca/
Posted on Mar 24, 2008
SOURCE:
Pt-47wx53g tv won't click over n than the power button will blink 5 times
IC4511 has failed on the DG board replaing the DG board as a unit i the only way to fix the issue. The DG board isnt serviceable
Jun 01, 2012 | Panasonic PT-47WX53 47" Rear Projection...
My Panosonic TV Model# PT-47WX53g has sound but no picture
Part is C509 located on D board:
It is a .47 @ 200 volts and the location is marked top and bottom on the board.
Examine the attached photos (cap has been removed but you will see exactly where it is located).
Let me know if you have questions
Jan 17, 2012 | Panasonic PT-47WX53 47" Rear Projection...
How do i remove the convergence board on my panasonic hdtv projection model number PT-47WX53G and is the any risk in electocution even after beeing unpluged
You have to remove all the cables and screws first...if you not sure how its done you can goto sites like www.TvRepairKits.com that have the parts and instructions to fix this yourself. Its a common failure on projection TV sets.
Aug 07, 2011 | Panasonic PT-47WX53 47" Rear Projection...
I need a lamp for a Pt-47WX53G set with an AP825 chassis. Can someone give me the correct part number?
This is a rear projection TV set. Therefore it has three CRT's in it and not a lamp or bulb like you see in a DLP tv. If tv isn't turning on it is most likely a convergence or power supply issue.
If you think you need a CRT then the part number is on the side of the CRT at the top. These are not easy to replace and are quite dangerous to handle if you have no experience.
I would not recommend any novice to attempt a CRT replacement.
Feb 24, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic CinemaVision PT-47WX53G : half the screen is distorted
did you try to try to adjust the vertical and the horizontal of your tv?
Oct 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT 47WX53G
Replace STK392-110 IC's ( both ) with PANASONIC part
# C5AA00000203.........DO NOT use generic IC's !
Terry.
Jul 22, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Double vision
Its a repair you can do yourself for under 40.00 if you can solder . You need to replace both convergence ICs they are both STK392-110. You can get replacement ICs at the following link with free instalation instructions with pictures. TV shops generally charge between 400 and 600.00 for this repair which takes about an hour.
Heres the link
Jul 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
168 people viewed this question
Top Televison & Video Experts
Ekse
