Question about LG Art Cool LA181CNW Split System Air Conditioner
My LS-H186 VML 1Metal Art Cool 12000 BTU Air Con does not heat up
The Aircon works fine on the cooling side but when the heating side is switched on the aircon goes into the heatig stage and the light in the front comes on showing that it is heating up, but the air coming out of the aircon is cold.
At first the aircon did not work on the cooling side nether but after I cleaned the filter the cooling side worked perfectly.
  • 674 Answers
You should also check the outside unit to make sure the coil is not clogged with dirt or grass clippings and the fan is working. The reversing valve that switches it from cool to heat could also be a problem. If it isn't shifting it will not switch between heat and cool.
Posted on Apr 29, 2010
Turns on and then turns immediately off. Does not blow any air.
Check if it gots a fuse or safety plug, maybe even a different outlet. Besides that I don't know maybe the filter needs cleaned? I'm not expert.
Feb 02, 2016 | LG LS-L1210HL 12000 BTU Heat and Cool Mini...
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    WHY DOES MY RADIATOR FAN COMES ON ONLY WHEN MY AC IS ON ON MY 88 TOYOTA COROLLA
    it is generally because the air con heat exchanger has to be cooled in order for your air con to work correctly and cool the interior of your car.
    The air conditioning utilises a gas by the name of freon. This gas is pumped around the air con system by a compressor. The gas, going through the aircon cooler or heat exchanger, starts to cool down. Depending on the system layout, the gas is forced through a very small aperture situated after the cooler. It reverts to a liquid, passes through the matrix in the car, a fan blows the interior air of the car through the matrix. The fluid picks up the heat, and cooler air exits the matrix and, (hopefully) cools the interior of the car. This endless cycle is repeated as long as the air con is powered on.
    Hope this brief description will suffice.
    Jan 25, 2011 | 1988 Toyota Corolla 4 Door
    I have installed an LMU246 with two heads. One 9000 BTU and the other is a 12000 BTU. The 12000 seems to work fine but the 9000 head dosent cool and when I tried it on heating, a c7 code comes...
    with the Lmu24 you have a variable speed compressor i wouldn't suggest attacking this repair on you own, get a Nate certified Sr. service tech out there and have them do cause your taking about high end cutting edge compressor technology, how ever if you need them i can email you a pdf copy of both owners and service manual.
    Oct 01, 2010 | LG LS-K1830CL Cool Mini Split Air...
    Frigidaire fac127p1a 12000 btu compressor
    The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
    Jun 04, 2010 | Frigidaire 12,000 BTU Compact II Room Air...
    I just installed a ductless mini split 12000. when I put power to it the outside unit compresser runs no fan the led read out just blinks very fast the remote does't do any thing
    One thing you need to check is Polarity. the 2 wires red and white, need to be on the same terminals inside as they do outside. this is very important.
    Oct 28, 2009 | LG LS-L1210HL 12000 BTU Heat and Cool Mini...
    Airconditioner LG LSk181-N2 shutting off
    Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
    Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
    Heather don't work
    If the unit still works on cooling you might have a faulty reversing valve/ heating plate. If you are confident with a multi meter you could test if they have power going to it and see if you have a faulty part but it would be best to get some tech help out
    Jan 07, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
    LWHD1200HR - LG 12000 BTU Heat / Cool Window Air Conditioner
    i have a lg lwhd 1200hr window ac the heating system dont work . it blow cold air out not heat. can you help me
    May 28, 2008 | LG Heat cool Window Air Conditioner
    LG Art Cool LA181CNW Split System Air Conditioner Logo
    319 people viewed this question
    Top LG Heating & Cooling Experts
    Donni Steen
    Tim Whalen
    Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
