Question about Garmin eTrex Legend GPS Receiver
Backlight no longer comes on?? Etrex Legend
I've had my legend now for about week, and all of a sudden it's backlight no longer works. The little "light" icon shows up in the bottom right corner of the screen, and shows itself lighting up when I press the power on/light on button, but no light comes on. I've checked the settings and it's set for 15 seconds. As a side note, all of a sudden the display is going blank except for a thin line that runs from top to bottom. I suspect this is the WAAS problem we've been hearing about, but both things happening at the same time????? Anyone else had a backlight stop working??
Had that problem too, it's a connection problem with the lcd screen. when you take the whole thing apart you will see 2 brass connectors that lead to the lcd screen (just under the thumb stick) I found mine was just a little sensitive to movement and one of the contacts had too much of a spacing i tighened it with a pinch of the pliers and seemed to work for me.. dont try if youre not sure what your doing, have it repaired by garmin. I'll try and get some pictures...
J
Posted on May 20, 2008
The backlight on garmin legend is dim - how do i brighten it
When the unit is on, press the bottom right side button on the GPS unit. A slider will appear to increase brightness, use your toggle to move the slider up.
Hope this solves your problem. If so, please come back and tell us, and rate our solution. Thank you.
Dec 20, 2009 | Garmin eTrex Legend GPS Receiver
Why does it take 10 minutes for my LCD Legend tv
Sounds like you have a faulty capacitor on your invertor..Gently press on the screen when there is no picture.is there light on the screen? If so, there is backlight but no video..hence a mainboard or power supply problem..If there is no backlight then the problem is the invertors or the power supply not supplying 24volts. The invertor is located on left or right hand side of screen..Check that all connections are secured and not loose.Check that the power supply capacitor tops on the power supply do not have bulging tops..If not, and voltage is reaching the invertor, then remove the invertor and check for bad solder joints and leaking capacitors.
Oct 17, 2009 | Televison & Video
How to get a replacement lcd cover/glass for a Garmin Etrex Summit. Mine is cracked.
I have a Etrex Legend (same size as yours) that no longer works - It has a good lcd cover.
email me at rsrogers at screaming dot net for full details
Rog
Oct 15, 2009 | Garmin eTrex Legend GPS Receiver
My owner's manual and reference guide was "drowned" while fishing. I need another one for my Garmin eTrex Legend personal navigator.
hi,
This should be the manual your looking for:
Garmin eTrex Legend Manual
This is a pdf file so you will need adobe or foxit to read it, I;m sure that most pc's come with adobe on them though.
I hope that helps..
Mike
Sep 01, 2009 | Garmin eTrex Legend GPS Receiver
Etrex legend has stopped picking up satalites.
I have had this problem occasionally and if you use Restore Defaults it appears to fix it. Using the front button go to Main Menu, Setup, System, move left and press the button button. Before I did this I just used to leave it a few weeks and it would suddenly be working again.
HTH
Peter
Mar 04, 2009 | Garmin eTrex Legend Cx GPS Receiver
Geocaching with Garmin Etrex Legend CX
The preloaded maps are VERY generic, mostly major highways. They are not useful for geocaching.
The good news is that you can download free topo maps created by a very generous Canadian soul, Dale Atkin. The maps are free but donations are accepted. He is also working on US topo maps. I've used Ibycus and Garmin topo maps and prefer the Ibycus version.
If this solves your situation, please come back and rate our answer. Thankyou.
Dec 27, 2008 | Garmin eTrex Legend Cx GPS Receiver
Garmin Etrex Legend Cx - no signal
Have you tried upgrading the unit's software. Go to Garmin.com and download the latest software for your unit. This will sometimes fix satellite reception problems.
Sep 28, 2008 | Garmin eTrex Legend GPS Receiver
Garmin Etrex display problem
Have you updated your Garmin unit software recently?
Mar 21, 2008 | Garmin eTrex GPS Receiver
Need details of internet setting of k220
hello i need the solution to use the garmin etrex legend gps .
Feb 12, 2008 | Garmin eTrex Legend GPS Receiver
Garmin etrex legend
I had this problem today, updated the software, now the unit seems to be working perfectly. The unit "crashes" (single line down screen center) as soon as it get enough satelites to work with WAAS.
Go to Garmin site for software updates. Download and install the WebUpdater. Once or unit is hooked up to your computer and you have internet access, the software will download and update your GPS with the latest software fixes. I had software Version 3.7. For the Legend, Version 3.9 fixes the problems with WAAS.
Jan 04, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
427 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
