7.5 Kg F&P washing machine, purchased in 2000. On turning machine on, the usual sequence of lights come on then when the lights are off, I turned it on (normal wash), did not change any settings. Water turned on and off a few times then error signal comes on. Tried again, from turning off at powerpoint, yet exactly the same problem. May I have your suggestion please?
    Genius:
  • 3,587 Answers
Sounds like the time needs to be replaced...seems like it's not advancing through the sequence..what's your technical skill level for doing this work on your own?
Posted on Mar 24, 2008
  • Patrick Michaels
    Patrick Michaels Mar 25, 2008
    well..seems you're ready to rock and roll...can you provide the maker of that machine please, and also part number or serial numbers.
SOURCE:
MY WASHING MACHINE WON'T FILL ALL LIGHTS WORK
I had a very similar problem with a WDL520p, it turned out it was the top display board that had a fault, I bought one on EBay for £12, and the machine is still goin 8mths later.
Nov 15, 2014 | Hotpoint Aquarius WDL540P White 60 cm...
Our Hoover 201M 5.0 kg washing machine has slowed down and taking 3 hours to complete a full wash. Not clicking from the Wash to spray rinse. Pls help!
The motor that drives the main switch needs replaced. It may require changing the switch & motor as a unit.
murf427
Aug 01, 2012 | Hoover Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Washing machine fault
Too heavy, overloaded, off balance is my take from what you describe.
Mar 08, 2012 | Washing Machines
Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
Dishwasher will not turn on, clean light is flashing
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Mar 05, 2011 | KitchenAid Dishwashers
Repair manual for a LT758S westinghouse washing machine
I have a Westinghouse LT758S 7.5 kg complete care washing machine everytime I turn my washing machine it will flash wash so I press start, it will beep 6 times and the medium and high lights will continue flashing on the water level??? I tried turning it on off but nothing what should I do?
Nov 20, 2010 | Washing Machines
Indesit wia 121 door lock keeps flashing and when put machine on it goes to a wash without turning dial to correct wash no.
these machines have a memory built into the pcb's which means that if they are switched off or there is a powercut etc they will just carry on from where they were in the cycle as soon as they next power up. if there is a black dot on the timer settings turn the dial to it then switch machine on and this should reset it for you after a few seconds. if this does not work count how many times the doorlock light flashes as this is a fault analysis code they will usually flas then pause for a second then flash again and repeat this sequence until a longer pause (3 seconds) then the sequence starts over.
hope this helps
Jul 28, 2008 | Indesit Washing Machines
What are the torque settings for the cylinder head 2000 subaru forester
This procedure is for the SOHC only.
E: INSTALLATION
1. CYLINDER HEAD
  1. Install cylinder head and gaskets on cylinder block. CAUTION: Use new cylinder head gaskets.
  2. Tighten cylinder head bolts.
  1. Apply a coat of engine oil to washers and bolt threads.
  2. Tighten all bolts to 29 Nm (3.0 kg-m, 22 ft. lbs.) in alphabetical sequence. Then tighten all bolts to 69 Nm (7.0 kg-m, 51 ft. lbs.) in alphabetical sequence.
  3. Back off all bolts by 180° first; back them off by 180° again.
  4. Tighten bolts (a) and (b) to 34 Nm (3.5 kg-m, 25 ft. lbs.) .
  5. Tighten bolts (c), (d), (e) and (f) to 15 Nm (1.5 kg-m, 11 ft. lbs.) .
  6. Tighten all bolts by 80 to 90° in alphabetical sequence. CAUTION: Do not tighten bolts more than 90°.
  1. Further tighten all bolts by 80 to 90° in alphabetical sequence shown in figure provided. CAUTION: Ensure that the total "re-tightening angle" [in the former two steps], do not exceed 180°.
May 24, 2008 | 2000 Subaru Forester
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
