Question about Microwave Ovens
Jenn air microwave oven door handle
How do I take apart the door on a jenn air microwave oven (model #M437W). There are no screws and no obvious way to disassemble the door (the handle broke and before I buy a replacement handle, I want to make sure I don't need any other parts).
This microwave was manufactured in 1992 and discontinued, but I've found replacement parts onlilne.
  • Microwave Ovens Master
  • 9,174 Answers
You can find helpful exploded view diagrams for the similar model M438 here: http://tinyurl.com/gv383
The model M437 is not listed, but the M438 is, and it should be similar enough to guide you. Just don't count on the part numbers being the same.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
SOURCE:
Microwave door handle broken
That's correct the door has to come apart. Just be careful that screen is actually a choke to keep in any microwave radiation. Put everything back exactly as you took it apart.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Insulation in oven door came loose and is now visible in the door window. The question is how do I take the door apart to place the insulation in its' proper place. There is a seal around the...
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 16, 2012 | Jenn-Air JMC8127DD Microwave Oven
The latch that opens the door to my Jenn-Air model M170 microwave oven is broken. I need to repair or replace it.
If the point of damage can be glued together with good bonding and further re-enforcement , it can be strong to withstand pressure.
So remove the assembly to try this out before you think there is no way out but to replace with the handle assembly from the service center.
The other option is to get one from a scrapped set.
Oct 01, 2011 | Jenn-Air M170 Microwave Oven
Handle broke off Microwave oven door can I repair? How can I access mounting screws? Where can I find parts?
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If the model number is correct, the part numbers for a door handle replacement is 56001139 and 56001136. There are two pieces with the door handle on this model oven. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you.
Dec 29, 2009 | Jenn-Air JMV8000 Microwave Oven
The opening door handel broke off.
This is a generic response to your comment
Look at the inside of the door, you will probably find a plastic strip which can be pried out. Underneath the strip, you will find the screws that hold the door together. The screws may be "torx" head.
Take pics of your door with your cell phone as you work and remember, most doors are spring loaded. Watgch your fingers.
Once the door is split open, replacing the handle should be a simple matter.
a
Sep 22, 2009 | Jenn-Air JMV8208A Microwave Oven
Broken Handle on Jenn-Air Model M406 Under Cabninet Microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Nov 24, 2008 | Microwave Ovens
Microwave oven
You'll need a new door handle.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 23, 2007 | Jenn-Air M439 Microwave Oven
Bottom screw on handle loose
All my micros had the screw go through the handle into the micro...no need to take door apart, just screw it back in. Why would you need to take the door apart?
Jun 12, 2007 | KitchenAid KHHS179LSS Convection /...
Microwave Ovens Logo
550 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
