Question about Frigidaire GLTF1670A Front Load Washer
The door lock on my frigidaire washer
The door lock on my frigidaire front load washer (gltf1670as1) will not engage, so my washer will not start. How easy is this to fix and is it expensive?
  • 33 Answers
The locking mec is jambed or broke easy fix hope this helps
Posted on Apr 29, 2010
FRIGIDAIRE FRONT LOAD WASHER WON'T START. DOOR LOCK WILL NOT LOCK. DOOR LOCK LIGHT IS OFF. PULL START HANDLE OUT/ NOTHING. HEAR CLICKING WHEN TURNING SELECTOR SWITCH/BUT WILL NOT LOCK DOOR OR TURN LIGHT ON...
Good Morning REDS, thank you for your inquiry!
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle, confirmed the latched is securely latched and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
Sep 11, 2013 | Frigidaire ATF6000ES Front Load Washer
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
All cycles are working except the spin cycle. I have visually inspected the wiring connections and motor and dont see any obvious issues. There are no error codes and the LED lights seem to be functioning...
Because of the high spin speeds of front load washers, the doors are equipped with a latch and lock mechanism to prevent the door from being opened during the washers operation. These locks will often be actuated by a solenoid or wax motor to ensure they remain latched during the wash cycle. This model uses a two stage lock that latches the door when the load starts, and then when it is time to spin, the second lock engages to ensure the door is properly secured prior to beginning the spin. When this second lock engages, it also closes a set of switch contacts (the auxiliary door switch) telling the control board the door is closed and locked. If for some reason this switch is not closed, the washer will tumble during what would normally be the spin cycle until the entire cycle is complete.
Jul 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
Fridgaire FTF530fs3 door lock buzzing and not locking, washer won't start
fit a new door lock as if it doesnt engage it wont allow the machine to start the washing cycle
May 31, 2011 | Frigidaire FTF530FS Front Load Washer
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Door lock wont engage
YOU MAY HAVE BROKEN THE BUTTON, A SMALL PIN LIKE PUSH BUTTON THAT PUSHES IN TO LET THE DOOR LOCK KNOW THE DOOR IS SHUT. YOU CAN USUALLY FIND A SMALL DIAMETER OBJECT LIKE WHAT IS IN A RETRACTABLE BALL POINT PEN TO SLIP INTO THE HOLE WHERE THE BROKEN PIN IS AS A TEMPORARY REPLACEMENT AND TO CONFIRM THIS IS ACTUALLY THE PROBLEM. IF IT IS, YOU WILL NEED TO REPLACE THE DOOR LOCK ASSEMBLY FOR PERMANENT REPAIR. DON'T SLAM THE DOOR SHUT BECAUSE THESE PARTS ARE MADE OF PLASTIC AND BREAK EASILY!
Jan 28, 2009 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Front loader not starting
First check if u can close the door with no or less clothes and see if the lock is engaged.. else if u find the door not locking see if there is any garments or threads blocking it.
Thankyou
Jun 17, 2008 | Frigidaire ATF6000ES Front Load Washer
On starting washer, terrible rat-tat-tat nose, door lock not engaging....
Try to turn can by hand and see if any noise produced by central bearing
May 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
403 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
